Honda Civic Type-R (2017 - Current) 10th Generation Civic Forum Type-R Discussions
Flexfuel for dummies
Old Jan 13, 2021 | 07:17 AM
Wongs2k's Avatar
Icon5 Flexfuel for dummies
Hey guys, so recently been thinking about getting a flexfuel sensor and kit so I can run ethanol. Before I spend the money on a Flashpro and kit, wanted to ask some basic questions.
Apologize in advance if these are dumb questions but I need to know the basics before committing on the purchase.
1. Can I use Hondata flash pro pre-programmed maps only to tune my ECU to support flexfuel? Do I still need a custom tune if I use Hondata flash pro?
2. What blend of ethanol can I run? For example can I run anything from a regular E10 mix all the way to E85 and any mixture in between? Can I fill up E85 on an empty tank or do I have to mix with 93 everytime? Some kits don't have a alcohol content gauge, how do you control the mixture proportion?
3. Is there an optimal mixture?
4. Is there any harm done to the car or engine if I do not run the optimal mixture?
5. Do I need to toggle back and forth between flexfuel tune and regular pump gas tune? Since pump gas usually is E10 anyway, is this even a concern?
Thanks in advance for any and all replies, appreciate it.
Old Jan 29, 2021 | 12:28 PM
Terry@BMS's Avatar
Default Re: Flexfuel for dummies
There are a few ways you can implement flex fuel tuning. A lot of it has to do with the mixtures used and whether mixing is an option for you. The R also has a relatively weak high pressure pump so that is going to also greatly limit the mixture you can run.
With a JB4 you can run up to ~30% E85 without having to add in a flex fuel sensor or reflash the ECU. E30 lets you just about max out the factory turbo performance also IMHO.
IAluder95
Engine Management and Tuning
Oct 22, 2017 03:20 PM
j0keefe21
14
Oct 15, 2009 12:25 PM
95GSRTT
May 11, 2006 10:34 AM
91integraLSVTEC
Oct 26, 2003 07:52 PM
01ITR#700
Apr 21, 2003 02:23 PM
