will o2 sensor throw code
Old Aug 8, 2006 | 05:37 PM
raphael's Avatar
Default will o2 sensor throw code
i have a 96 civic ex with a stock y8 and it bogs real bad at low rpms, no codes. ive searched and seen that it could be the o2 sensor. if it ws my o sensor wouldnt it throw a code?
Old Aug 8, 2006 | 05:42 PM
Paxil4x4's Avatar
Default Re: will o2 sensor throw code (raphael)
Yes, but I would recommend getting it scanned unless you like guessing with expensive parts.
BTW The stock cast iron manifold on my car cracked and it check engine light gave a o2 sensor code it seem like it is a common problem. I also never heard an exhaust leak.
Old Aug 8, 2006 | 05:43 PM
93allmotorcoupe's Avatar
Generally, it should be throwing a code 1 or 41...but it is possible for there to be no code and the car can still run shitty. If its never been replaced, its definitely not a bad idea either way.
EJ6_ROY's Avatar
O2 sensor would throw code, but I doubt that's it.
Old Aug 8, 2006 | 05:44 PM
SL!M's Avatar
Yes it will throw a code. I agree with packthis, if you want to throw your money away go ahead. I would get it looked at, scanning it won't do anything unless they use a scope to check the sine wave that the 02 sensor can produce then you will see if it needs to be replaced.
Mr.Civic
Apr 6, 2013 09:51 AM
importnoodles
Mar 29, 2008 10:20 AM
b_serious
Jan 26, 2006 05:22 AM
s14hybrid
Nov 24, 2004 05:16 AM
