Whinning noise with PE belt! HELP!
Hi all,
After i change to the PE timing belt i get this whinning noiseor sound everytime i go above 2000rpm.Gets louder as the RPM climbs. Asked a few "performance" shops and all said PE belts are suppose to make those noise since they are harder than normal belts. to all who have this belt....is this true? I have new bearings and water pump. If i have to take everything out and re-install it,whats the correct torque spec on every screw/bolt/nut when installing? (i'm thinking this is one of the cause for the noise) BTW this is a B16B motor. Thks all! https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: Whinning noise with PE belt! HELP! (Takashi1978)
Sounds like you might have it to tight.
Re: Whinning noise with PE belt! HELP! (Davep)
How can i be sure?
Which areas should i look into? |
