Weird problem with JDM EG city lights
I'm not sure if this is normal or if something is just wrong with the reflectors in my headlights, but when the city lights are on, the passenger side is a lot dimmer than the driver side. I know it's not the bulbs since I replaced both sides with fresh bulbs. Does anyone else have this problem? Here are some comparison pics I snapped:
Driver Side: http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg Passenger Side: http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg Chad, if you see this, thanks again for the help https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Weird problem with JDM EG city lights (Dangydang)
Have you double-checked all of your wiring? Also, are you sure that each of the sockets is seating properly? It almost looks as if the focal points of the two bulbs are different inside the lenses, causing one to appear brighter.
Modified by Padawan at 10:53 PM 8/8/2004 |
Re: Weird problem with JDM EG city lights (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Have you double-checked all of your wiring? </TD></TR></TABLE>
Yeah, all wiring is correct. It seems like the problem lies in the reflector. |
bump im having the same problem but mine are oppisite
I have the exact same problem with mine https://honda-tech.com/forums/images...s/emsmilep.gif , but I tired new bulbs, aligned the lights, triple checked the wiring and it was still the same.......... I am guessing the reflectors inside the housing is different or it could be the angle that your looking at your head lights
im pretty sure its the reflector because my old ones were like that and then i got projectors and hated them so i traded some guy for stock and now both are bright. good luck. DUNDADA!!!!!!!!!
Re: Weird problem with JDM EG city lights (JDMGSR EG)
try switchin the entire kit on both sides to check ur reflectors
Re: Weird problem with JDM EG city lights (99CivicExCoupe)
ohhh does anyone know how to make the corner lights turn off when u turn on the headlights so that they only come on when you blink
Re: Weird problem with JDM EG city lights (bonta-kun)
mine do that on my jdm headlights also.. i think its the focal points as people already said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun »</TD></TR><TR><TD CLASS="quote">ohhh does anyone know how to make the corner lights turn off when u turn on the headlights so that they only come on when you blink </TD></TR></TABLE> you disconnect the red/yellow wire from the corner light to make it off and only on when you turn on the turn signals/hazards. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangydang »</TD></TR><TR><TD CLASS="quote">
<FONT COLOR="pink">Chad, if you see this, thanks again for the help https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif</FONT> </TD></TR></TABLE> NP, Good Buddy !!!! We should try eliminating the corner lamps to see how they would look....looks good I am bothered by the dim side light too..... |
Re: Weird problem with JDM EG city lights (H2ouup2)
http://bustedshocks.com/Chad/City_Ri..._Rights_01.jpg
http://bustedshocks.com/Chad/City_Ri..._Rights_02.jpg http://bustedshocks.com/Chad/City_Ri..._Rights_03.jpg http://bustedshocks.com/Chad/City_Ri..._Rights_04.jpg <FONT COLOR="blue">Here you go I dug up some old pixors, and it looks the same passenger side is dimmer......</FONT> |
Woah Chad! Secret, forgotten pixors of your caaah...wasn't ready for that https://honda-tech.com/forums/images...s/emsmilep.gif I guess this is normal though since others are having the same problems.
