trans swap for taller overdrive 2000 Civic Si
Hi all - I would like to know if there is a transmission that will fit in my 2000 Civic Si, B16, 5 speed that has a taller overdrive (meaning lower numerical gear ratio - higher car speed at same rpm)? Was told an Acura trans is like this, but have not run across any charts, etc. giving this information - any input?
Re: trans swap for taller overdrive 2000 Civic Si
Install an LS 5th gear from a 92-01 Integra LS trans.
Originally Posted by chuck chainz
(Post 51931510)
Yes, the '04-01 Integra LS 5th gear set is a drop in swap inside the S4C ('99-00 Civic Si) transmission. It will drop the engine speed by 1000 RPM at 80 mph.
and through the entire engine's torque multiplier out the window. I did this 5th gear change on my EM1 and instantly regretted it. use a GSR 5th instead.
If you're interested in the thread I gave feedback on this change the year I performed this abomination, leu me know |
Originally Posted by TheShodan
(Post 51931926)
Originally Posted by JRCivic1
(Post 51931934)
The standard B16A2 has no torque... so I could see how this could be an issue. The GSR 5th gear set could be a good compromise between the stock 5th gear pair and the LS 5th gear pair... or just add a bunch more displacement or HP and the tall LS 5th gear pair will work just fine. ;)
Torque multiplyer concept is still applied even in the torqueless wonder B16A2. But going into that takes this thread off course. |
I recall someone changing out the final drive on the b16 with a LS.
I want to say I'm still getting 29mpg in my si. If it was 24 or something I could reason a swap. But the si just drives like a motor cycle
Originally Posted by chrysler kid
(Post 51932254)
(Post 51932254)
Hey, thanks for input. Went with a little bit taller tires, made a nice change to audible taching out factor, but was noticeable how it did kill off the bottom end. The car seems to love churning away at 4000 rpm, I just get tired of listening to it. Less invasive than swapping gears or trans, cool you guys know how to do that - thanks - Cody
Also, I am new to this website - I put an add in the classified section, but it is not there today. It might have been taken down because I did not have a card with the required info in the photos with the cars, not sure. Any input? seemed like they posted no problem. A guy welcomed me as a new member, seemed to be the web sight guy, now I can't figure out how to contact him.
Originally Posted by cody61
(Post 51935301)
(Post 51931926)
If you're interested in the thread I gave feedback on this change the year I performed this abomination, leu me know Note that hat all of these issues will be even more noticeable with your shorter geared trans and your higher revving, less torquey b16 |
Mountains? best get torquey. Austin has some nice roads but you still have to be careful or you'll end up off the road.
