traction problems
i have this problem wtih traction because my torque is high. (over bored pistons and high compression) and when i race i like to slam on the gas and i lose traction for like 3 seconds and sometimes i do an rolling traction where smoke will come to the tires a little. someone told to barly step on the gas and then slam it so you get off the line first. now wouldn't i lose off the line because i am not flooring it. i havn't found a guy to race to try this method. how would you solve the traction problem. i have an automatic so i don't know what answers i will get because most of you drive sticks
Re: traction problems (AutomaticB16)
Wheelie bar ... you should be planted no prob after that https://honda-tech.com/forums/images/smilies/emwink.gif
Re: traction problems (VolpeOwnsU)
how would you solve the traction problem? |
I used to drive an auto and the only way I would race would be from a roll simply b/c honda autos suck from a stop. If you have traction problems with an auto in a honda then something is wrong.
but to help try some suspension work, stickier tires, also to launch try and stall it up using the brake. Just go to a deserted road and try a few different methods and see what pulls best. |
Re: traction problems (foozball-26)
thanks everyone!!! i will try to see whats best.
you might even what to look into a a set of z10 raduis arms
how do you have a automatic b16 that would break your tires loose??
What are your mods??? How much torque??? |
Re: traction problems (degooser)
how do you have a automatic b16 that would break your tires loose?? What are your mods??? How much torque??? |
my mods are ctr pistons overbored (0.25) and knife edge crank and stock rods got narrowed. cold air and higg flow cat and greddy sp. i don't know how much torque i have can't really sayd but when i dyno my car i will show you guys the slip. but i might dyno it after i finish the motor. i might dyno it soon just to see what i pull off with an automatic built bottom end. how my tires get loose who the fuck knows. maybe i will make a video and post it up to show you wtf is going on
[Modified by AutomaticB16, 5:28 AM 2/4/2003] |
post a vid...
I would really like to see your car...! |
sure, but i gotta know how to do it. teach me and i can. right now i have windows 98 on my computer so i might have to use my brother computer to do it. teach me and i will. hell if you live near south california, i will show you in person
[Modified by AutomaticB16, 5:42 AM 2/4/2003] |
post a vid... I would really like to see your car...! |
Re: traction problems (FrostyDC4)
you know I'm thinking he is doing neutral drops from 6k and thats his traction problems https://honda-tech.com/forums/images...es/emsmile.gif
damn, traction problems with automatic b16. thats unheard of.
you know I'm thinking he is doing neutral drops from 6k and thats his traction problems https://honda-tech.com/forums/images...es/emsmile.gif anyways...maybe next time you are down in SD hit me up and ill check out your car... |
