Timing belt tensioner bolt not turning anymore CW to tighten
I put a new timing belt on. Then i was tightening the tensioner center bolt to 44-47 N*m i cant remember exactly what was supposed to. I'd turn the crank and retension, turn and re-tention that bolt. It was tightening but the belt seemed too loose. So I started torquing it until it wouldnt go anymore CW past 45 or whatever on my torque wrench to more like 60+ N*m. Then I tried backing off that bolt and seems stuck so it wont go CCW or CW. Im sure I could eventually break it back CCW. The belt seems ok tension but not quite as tight as the old belt. What are some good tricks to see if the belt is not tight enough. Besides cranking my engine and seeing if my car self destructs.
Re: Timing belt tensioner bolt not turning anymore CW to tighten
Torquing the tensioner bolt down.............does not tighten the belt. What you just did was completely tighten the bolt into the block. I would be very careful right about now.
Unfortunatly, you have seriously over tightened the bolt.
All you can do is loosen the bolt and deal with whatever damage has been done or will occur during loosening. You may also now be forced to replace the tensioner too as it now may be distorted and not work the same as it normally would. I haven't actually taken a really solid look at the tensioner to know how it's constructed so it may be able to handle that extra clamping force you put on it, but it may not also. Just be prepared if the tensioner is not the same after this. Hopefully you haven't damaged the block, you will know once you back the bolt out so that you can totally remove the tensioner and inspect it. Good luck. |
Originally Posted by tony_2018
(Post 50483007)
Guess I could have damaged the block's hole threads going past 44 Nm is that what youre saying to be careful with not doing? When I finally cranked, it was loud around where the timing belt was I think. And a burning rubber smell. I left the upper cover off. And so flapping could be seen about 1/2 in to and inch you could seen on the part of the belt that goes from the camshaft straight down to the crankshaft (front, forward). Then uncranked and you could pressed the belt in like a inch easily. So I should replace the tensioner, right? The belt has same dimensions as old Honda OEM and same part number. I compared their dimensions new vs old. |
Tightening the belt to shit WILL NOT tighten the belt.
Just hope you didn't screw anything up with that stunt, and try loosening the belt and tighten the belt the correct way. |
Originally Posted by 98civdx
(Post 50483445)
Tightening the bolt to shit WILL NOT tighten the belt.
(Post 50483445)
(Post 50483445)
Also, I cannot tighten the belt without removing the bottom TB cover and getting hold of the tensioner...correct? Why do they have that bolt accessible through the bottom TB cover? You cannot move the tensioner up or down so that hole seems useless and made me think it was for adjusting the TB tension. |
Read the service manual procedure.
PLEASE read the PAQ sticky about timing belt replacement before you totally destroy your engine. you have zero idea what you are doing.
edit- ron beat me to it by 30 seconds. |
1 Attachment(s)
No, no, that's not how you tension the belt properly either. Quit fucking with shit that you don't understand. Buy/borrow/download a FSM, or ASK BEFORE FIDDLING.
Attachment 518632 You're welcome. |
Originally Posted by NotARaCist
(Post 50483560)
Of course not. There's a plug in the cover to give you access to the adjustment bolt. You didn't notice the plug? You went through the whole process of pulling the crank pulley, and didn't notice the plug? You got everything off, and didn't realize that the tensioner was spring loaded? You loosened the tensioner bolt, and didn't see the spring pull the tensioner back?
Do you see what I'm getting at? Put the tools down, open your eyes, and pick up the FSM before you break something else. No, the tensioner bolt didn't "stop" because it "hit the correct tension". It stopped because you overtorqued it. That bolt doesn't actually adjust anything. It holds the tensioner pulley in place. It's position in absolutely no way controls the tension of the belt. The procedure in the FSM properly tensions the belt, and then tightening the bolt down to spec holds it in place. Period. That's it. If you just want to do the work, get the FSM, and follow the steps to a tee. If you actually want to understand what's going on, then open your eyes, do a little bit of critical thinking, and maybe learn a little bit about simple machines (which is middle school level shit). |
(Post 50483654)
I did those procedures for tensioning in my own way before by rotating the crank then tighten just not "3" teeth and from TDC. Now i did exactly according to the fancy procedures and still doesnt add tension to the belt. So I'm thinking the tensioner is not working either because of me misunderstanding how the tensioner tensions. Now I understand the tensioner should work on its own. I will call tomorrow and see if the dealership carrys tensioners for a 98 civic. |
A few thoughts...you said you had started the engine after you had overtightened the bolt, but not the belt...and that you saw the belt, in motion, flapping about and smelling of burning rubber, right?
If so, you have made that timing belt a time bomb. You NEED to replace it with a fresh un-murdered belt in addition to a new tensioner, tensioner spring (maybe), tensioner bolt, AND a very careful inspection of the tensioner bolt threads (which are aluminum BTW and rarely come out of a serious overtorque without extensive damage that you sometimes cannot see, but days down the road may have your tensioner simply pop off the block and proceed to fuck your entire engine)...you may need to repair/have someone repair those threads...DO NOT trust that they will simply hold from now on. If you are not comfortable with doing this extensive work yourself, then unhurry yourself and pay someone to do the job right...otherwise you will likely end up needing a new motor in the near future. P.S> another bit of info. The tensioner itself is just a sealed-bearing flat faced pulley mounted on a backing bracket with a pivot-pin hole, the tensioner pulley itself doesn't actually tighten the belt, it simply provides a surface for the belt to rotate smoothly on. the load on the belt is initially applied by the tensioner spring pulling on the tensioner pulley bracketry (which pivots radially on a pin), and then properly set by the 3 tooth rotation putting a rotational load on the belt, placing the tensioner pulley and spring at the proper distance, at which point the tensioner bolt is tightened to clamp the tensioner pulley against the engine block, setting correct timing belt tension. whether you knew this already, i do not know, but it never hurts to have mechanics explained in simple (albeit, repetitive) terms. |
Claims to be a critical thinker, thinks that the bolt controls the tension of the timing belt.
https://i1272.photobucket.com/albums...pse31239da.gif So, how much deflection is there in the belt? |
Originally Posted by eghatch9295
(Post 50483559)
PLEASE read the freakin FAQ sticky about timing belt replacement before you totally destroy your engine. you have zero idea what you are doing.
(Post 50484668)
FIXED
Here's the likely sequence of events needed to save your block IMO.
Take the bolt out and inspect the threads. If in fact there are any threads lubricate them WELL with WD-40 and chase them with a tap of the proper size and pitch. Then inspect again. I'm betting the threads are done though based on the unwillingness of the bolt to turn either way. You'll likely be drilling the threads out CAREFULLY and inserting a time-sert or maybe just some helicoil if you wanna do it the meh way. If you're not comfortable with that it's time for the block to go to the machine shop. After than get a new bolt, tensioner, and belt and follow the proper procedure this time. Good luck. |
FUXED
Oh wait, were you guys talked about each other's posts? I'm just talking about this thread. |
(Post 50484696)
FUXED
Originally Posted by burnoutboy
(Post 50484680)
If you're not comfortable with that it's time for the block to go to the machine shop. After than get a new bolt, tensioner, and belt and follow the proper procedure this time. I am going to inspect the bolt and bolt hole next. The bolt catches when going CW to tighten even though i havent done it full torque to 44 N*m, I have tightened back slightly with a wrench turn and catches snug. If I am able to torque a new bolt (I ordered a new one from hondapartsnow as well as a new spring for tensioner) to 44 and seems to hold the tensioner snug, should I leave it alone? Or, should I go ahead and drill out then Hellicoil it or another insert since I know I really put A TON of stress on the bolt & hole threads? In other words, how would you proceed now that i got the bolt free'd and I'm getting a new bolt in the mail? And say that it catches the hole snuggly? Would you not worry about drilling out and inserts or would you just put the new bolt in and not worry about it as long as it torques to spec?
(Post 50484680)
Post a pic of the threads. At the VERY least chase them with a tap.
(Post 50483474)
Fixed.
Originally Posted by WaryDriver
(Post 50483525)
SHIT. I thought that center bolt tightened the belt but it really just holds the tensioner in place. TO TIGHTEN THE BELT, I MOVE THE TENSIONER THING UPWARDS? Then secure that position with the center bolt?? HOW DO I KNOW WHEN THE BELT IS TIGHT ENOUGH (HOW FAR TO SET THE TENSIONER UPWARDS)???
What is more likely.. Did I damage the tensioner OR the bolt hole threads in the block by using a breaker bar to tighten that center 14mm bolt way beyond torque spec? I was hammering an extension with a hammer to try and tighten the belt with that bolt. DAMN Also, I cannot tighten the belt without removing the bottom TB cover and getting hold of the tensioner...correct? Why do they have that bolt accessible through the bottom TB cover? You cannot move the tensioner up or down so that hole seems useless and made me think it was for adjusting the TB tension. I would replace the tensioner and the belt. Inspect the bolt, and the threads very carefully. thread it in a few times without the tensioner to be safe. There is a hole in the timing cover to access the tensioner bolt. You don't move the tensioner, the timing belt does. |
Below are images I took of the hole and old bolt after removal. Reminder- I'd overtightened the bolt severely and wanted to know if I should be concerned. I installed tensioner with the new silver bolt with some thick grease smeared all over the threads turned by hand as far as i could, and I was hoping it would be slightly longer than original bolt but wasn't (That was the main reason I ordered a new bolt because i read they made them very slightly longer to grab some extra threads). It tightened normally to 40N*m. It looked like the old brass color bolt was undamaged. How do the hole's threads look from my pictures? And what about that indention around the hole, is that something I created or is it supposed to have that carved out indention? Here is a link to even more photos I took like 25 photos i took at different angles (OvertightenedBolt - Album on Imgur) and I selected the ones below from that album. Do look through my album because maybe there is a more telling photo than these. Almost did not get this bolt out it would not budge either way for so long. Then finally CCW it came loose, I was nervous getting it loose again.
https://cimg0.ibsrv.net/gimg/honda-t...872b67c865.jpg https://cimg4.ibsrv.net/gimg/honda-t...f670021b0e.jpg https://cimg5.ibsrv.net/gimg/honda-t...329ebd491f.jpg https://cimg6.ibsrv.net/gimg/honda-t...c0dfa67f88.jpg https://cimg7.ibsrv.net/gimg/honda-t...d3549820e3.jpg https://cimg8.ibsrv.net/gimg/honda-t...bc20f0d9ff.jpg https://cimg1.ibsrv.net/gimg/honda-t...a881e8974f.jpg |
they don't look awesome. you MIGHT get away with it, the bolt and threaded area are both long. you *could* use some threadlocker for insurance, and know when you next do the job it will need some extra work.
