Time for a new valve cover gasket?
D16Y8 99 Civic EX
https://cimg0.ibsrv.net/gimg/honda-t...68717cc72b.jpg https://cimg1.ibsrv.net/gimg/honda-t...216397553e.jpg This seems to be a common oil leak / gunk buildup area on honda engines. Im just guessing where its coming from the valve cover gasket area? Any other places to check before I go about installing the new gaskets? |
Re: Time for a new valve cover gasket?
Originally Posted by agb22
(Post 51262642)
That's a great point. I'm in the same predicament with mine but I didn't tought about it. Thanks
While you have the VC off, you might as well check the valve lash and adjust if necessary, and change the spark plugs.
Originally Posted by Caoboy
(Post 51263622)
Any recommendations for an aftermarket dizzy? Hondas are like 3x the price |
There is an O-ring on the distributor that you can replace. Unless the shaft is bad I'd replace the O-ring.
It'd be better to rebuild the distributor with OEM parts than to buy an aftermarket one. |
(Post 51263785)
It'd be better to rebuild the distributor with OEM parts than to buy an aftermarket one. To rebuild the dizzy order parts thru Honda? I've never rebuilt one. Not sure what I'd need to order |
There is an internal seal on the shaft, as well as an external O ring.
If there is oil inside your cap, it's the shaft seal. If it's just leaking out, replace the o ring. https://youtu.be/Mp15Z2fXW0Y if nothing else is failing, ignition wise, in the distributor, you don't need to replace anything else. |
(Post 51263794)
- use a wire brush to scrape the Calcium buildup
- spray some engine degreaser to remove the caked up oil on the block |
