Throwing CEL code 3 Map sensor
I switched the map sensor with one that my friend had but its still throwing the code..... can anyone help me????? should i buy a new one???
Modified by 95RedCoupe at 1:29 PM 6/12/2005
Modified by 95RedCoupe at 9:59 PM 6/12/2005
most of the time when a map senor code is thrown its in the wiring and not the sensor. we have seen this alot in honda's. We check the code then replace the sensor same thing happens then we bust out the mm and the manny. and trace it to the problem source
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote">most of the time when a map senor code is thrown its in the wiring and not the sensor. we have seen this alot in honda's. We check the code then replace the sensor same thing happens then we bust out the mm and the manny. and trace it to the problem source</TD></TR></TABLE>
3 things possible though: hose leak, wiring, or map sensor itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 »</TD></TR><TR><TD CLASS="quote">did you buy the right one? There is one for the firewall and one for the TB</TD></TR></TABLE>\
uhh, one is a TPS and one is a MAP
FSUseminoleEM1
Feb 19, 2010 08:34 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
