Re: temp guage goes to "h"
i have a 1.8 b18c1
Originally Posted by b18Aaron
(Post 42295369)
i have a 1.8 b18c1
its the obd1 years im not really sure what ones those are
oh man LOL i know the a1 was the 90s obd0 stuff then the a2 or i think the b2 was obd 1 for the integras. let me look for it though
get a rad for what ever car you have... i have a 95 civic with a gsr swap turbo, i have a 92 - 95 rad.. hope this helps you
Originally Posted by miguel329
(Post 42295630)
could the smoke from my exhaust still be white but not have a bad head gasket?
okay so i just replaced the fan switch, coolant temp senser, lower radiator hose and replace coolant. STILL going past the "H" and the fan still wont kick on. Also my exhaust is white but i checked under the oil cap and its not like a milkshake also i checked the dipstick and it dosn't have air bubbles or fluent in it. im thinking i need a thermostat now because i just reread the post mmy two hoses are different temps. HOPEFULLY that solves my problem.. :scared:
if anyone has had this problem please help |
oh yeah now my heater air is cold
drain your oil and look in there for coolant.
does it drive funny or not as good as it used to? this went from a possible rad thing to a HG. oh and stop driving it or you'll have bank of milling to do on that head. |
if you dont have coolant in the system the heater will not blow hot.
well i just drove again and the heat was warm and i felt the hoses and one is scalding hot and the other is freezing im thinking i need a thermostat. il get one today and tell you guys what happens
a cold radiator hose is caused by a bad thermostat not opening up. replace it..
yeah im going to either tonight or tomorow HOPEFULLY tonight
welllll i just replaced my thermostat and guess what. the hose is still cold and now my speedometer wont work. i honestly dont know what to do now.. if anyone knows how to fix any of this and you live in washington pm me
Originally Posted by Red_Army
(Post 42384431)
(Post 42402425)
yes i did once today and once tuesday
ohhh i thought you mean drain no i dont know how to bleed it
(Post 42402572)
Originally Posted by RICKSAUTOMOTIVE
(Post 42402636)
this is probably the problem. do you have a 12 mm deep socket on a 3/8 drive and a 6 inch extension (also 3/8 drive ) and a 3/8 ratchet? this is the easiest way to bleed it. a 12 mm wrench works okay too
you see the thermostat housing you removed to replace the thermostat? (thats actually called the water outlet) that part the hose goes onto. but okay right down there is a funny looking nut with a nipple o it. kinda looks like an axle grease port on diesel chassis...see what i'm talking about
loli dont really understand... is it by the thermostat housing?
wait is it right next to the upper radiator hose?
(Post 42402770)
