stripped flywheel bolt
ok i have been working with a friend taking out my old engine for the jdm d16 and we have a problem. One of the bolts on the Flywheel to the old block is so STRIPPED. the Gator tool doesnt grab it, ive tried the GrabIt method of drillin in and drilling out, but my electric drill doesnt even move cause its so tight as well. I need to get this drill out! i have to take my friend back to his home (45 min away) and my honda is the only transportation.. so basically we need to get this done. seems like everything has been held up on this one damn bolt.. How can i get this out???? Please help!
Re: stripped flywheel bolt (CivicUtah)
NAPA has this set of tools that grab the strip bolt by a reverse lock, work tomorrow so I will get the part number for you.
this one is the professional version of the gator tool. |
Re: stripped flywheel bolt (EKGIZMO)
Yo
https://s7.sears.com/is/image/Sears/...XC4T3GeuZqkqn9 Things saved my ass so many times https://honda-tech.com/forums/images/smilies/emthup.gif http://www.sears.com/shc/s/s_1...Num=2 |
only problem with that is i now have little to no money left.. when i went to get oil/cooland/trannyfluid etc today i was 2$ short and he had to do discounts like mad... ugh
Well sounds like your SOL welcome to the Honda world and working on cars. Next time in the future maybe you will plan ahead for such situations. Good Luck.
actually that craftsman kit does look pretty nice.. is there any place open all the time that would have something like that? like a wal-mart or something?
smileycvc
Re: stripped flywheel bolt (CivicUtah) 11:16 PM 9/16/2007 -------------------------------------------------------------------------------- Well sounds like your SOL welcome to the Honda world and working on cars. Next time in the future maybe you will plan ahead for such situations. Good Luck. ya well.. have a flywheel bolt from hell wasnt really something i could have planned ahead for. yes shit happens and all but i could not have expected a single fuckin bolt to hold everything up for 9 hours now. https://honda-tech.com/forums/images...s/emthdown.gif ( we went to sleep for a few of those hours tho https://honda-tech.com/forums/images...es/emdgust.gif ) |
theres no auto stores open at all ( drove allthrough salt lake ) http://images.honda-tech.com/set1//smile/emcrook.gif https://honda-tech.com/forums/images...s/emthdown.gif
bet you used a five sided on it didnt you...
i usually just use a dremel and cut a knotch down the middle, so i can use a flathead on it...but i'm not sure you could back that bolt out that way..must be over torqued. |
Cut a slot in it with a grinder, and put a large straight screw driver against the slot and tap with hammer. Pretty easy, I had to do this not too long ago.
NAPA PART # IS 394100 IS ONLY $18.99
Re: (THE GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GUY »</TD></TR><TR><TD CLASS="quote">Cut a slot in it with a grinder, and put a large straight screw driver against the slot and tap with hammer. Pretty easy, I had to do this not too long ago.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (-Gambit-)
thanks guys i got it finally lol. but couldn't find anywhere that had that bolt so i had to put the old one back on when i put it on new motor =\
if it was so stripped how did u tq it down properly?
Re: (Malakai)
it was able to catch good on a socket when going right to tighten, just to the left it was like a slip n slide https://honda-tech.com/forums/images...s/emthdown.gif what are you supposed to torq it to -_- i dont have a torq wrench and have already been running the car for 130 miles
that craftsman set has saved my ass many times. well worth the buy. i dont know what id do without them......
