SO WHAT IS THIS WORTH THEN.. LOL...
i figured hey why not, someone else is doing it.. currently forsale by the way locally.. tell me what you think..
00 gsr front seats 00 gsr back seats 00 gsr suspension all the way around w/ disc brakes sloted front rotors blox camber kit all around tokico illumina 5 way w/ skunk coils ebay front strut bar ebay lower rear tie bar sir jdm corners ( not in pic but currnent as now ) sir led wing ( not in pic but currnent as now ) ex/si cluster clifford alarm with after market remote 6000k hid jvc head unit si eg door panels w/ side pockets red/ clear jdm tail lights ( not in pic but currnent as now ) 2.5 inch thick alunimum radiator d16z6 (92-95 si/ex vtec ) ported and polished head crowler retainers crowler turbo valve springs stock cam nology wires oem plugs d16y8 block ( 96-00 vtec block ) micro polished crank nuforms block guard vitara pistons 8.5 compression nrp piston rings eagle forged h rods arp rod bolts alc rod bearings new oem crank bearings new oem rear main seal new oem oil pan gasket new oem oil pump new oem timing belt new oem water pump new oem head gasket arp head studs act pro lite fly wheel 8lbs exedy stage 2 street pro clutch kit aem fuel rail gsr fuel regulator dsm 450 cc injectors greddy tdo4h 15g kit **carb** greddy type s blow off valve greddy turbo timer turbonetics 3 row inner cooler p28 chipped chrome pro street tuned autometer 20 psi boost gauge walbro 255 lph fuel pump 195-50-15 kuhmo ecsta 15" desmond evo regas 37 offset in some pictures right now there is less than 3k on the build, i havent even done an oil change yet. castrol sythetic with k&n lilter. stock pipping to gsr canister, needs to open up pipping and you would unleash the beast. right now car is around 8.5 psi.. this is a small turbo so you get fast spool, but not too small either. same thing as a t28 hybrid. but better because of greddys technology. stalls some times but starts right up... needs to be retuned.. ** missing glove box **** this is old pictures, the front bumper is now replaced with a similar color. https://img520.imageshack.us/img520/...arry014aq6.jpg https://img184.imageshack.us/img184/4151/egpr3.bmp https://img514.imageshack.us/img514/1373/larry1co8.bmp https://img410.imageshack.us/img410/3336/larryfo7.bmp https://img148.imageshack.us/img148/...arry007nr3.jpg https://img110.imageshack.us/img110/162/larry013cz2.jpg |
Re: SO WHAT IS THIS WORTH THEN.. LOL... (jdmcivicturbo)
more then the other guys but still has no tech.
This is an outright for sale topic thinly veiled as a "what's it worth" topic.
Browse the market place, craigslist, etc. and guage the value. If you want to PM me the other topic I'll lock it too. See some people actually have an honest question about the value of a car they own, or ar looking to buy, and this forum would be the place to ask such a question. In this case it's obvious that you're doing it just because someone else did it. Post this exact topic in the FS forums and add "testing waters" and/or "make offer" and see what you get. |
