SO WHAT IS THIS WORTH THEN.. LOL...
i figured hey why not, someone else is doing it.. currently forsale by the way locally.. tell me what you think..
00 gsr front seats
00 gsr back seats
00 gsr suspension all the way around w/ disc brakes
sloted front rotors
blox camber kit all around
tokico illumina 5 way w/ skunk coils
ebay front strut bar
ebay lower rear tie bar
sir jdm corners ( not in pic but currnent as now )
sir led wing ( not in pic but currnent as now )
ex/si cluster
clifford alarm with after market remote
6000k hid
jvc head unit
si eg door panels w/ side pockets
red/ clear jdm tail lights ( not in pic but currnent as now )
2.5 inch thick alunimum radiator
d16z6 (92-95 si/ex vtec ) ported and polished head
crowler retainers
crowler turbo valve springs
stock cam
nology wires
oem plugs
d16y8 block ( 96-00 vtec block )
micro polished crank
nuforms block guard
vitara pistons 8.5 compression
nrp piston rings
eagle forged h rods
arp rod bolts
alc rod bearings
new oem crank bearings
new oem rear main seal
new oem oil pan gasket
new oem oil pump
new oem timing belt
new oem water pump
new oem head gasket
arp head studs
act pro lite fly wheel 8lbs
exedy stage 2 street pro clutch kit
aem fuel rail
gsr fuel regulator
dsm 450 cc injectors
greddy tdo4h 15g kit **carb**
greddy type s blow off valve
greddy turbo timer
turbonetics 3 row inner cooler
p28 chipped chrome pro street tuned
autometer 20 psi boost gauge
walbro 255 lph fuel pump
195-50-15 kuhmo ecsta
15" desmond evo regas 37 offset in some pictures
right now there is less than 3k on the build, i havent even done an oil change yet. castrol sythetic with k&n lilter.
stock pipping to gsr canister, needs to open up pipping and you would unleash the beast. right now car is around 8.5 psi.. this is a small turbo so you get fast spool, but not too small either. same thing as a t28 hybrid. but better because of greddys technology. stalls some times but starts right up... needs to be retuned..
** missing glove box
**** this is old pictures, the front bumper is now replaced with a similar color.
00 gsr front seats
00 gsr back seats
sloted front rotors
ex/si cluster
6000k hid
jvc head unit
crowler retainers
stock cam
nology wires
oem plugs
nuforms block guard
nrp piston rings
eagle forged h rods
arp rod bolts
alc rod bearings
new oem oil pump
new oem timing belt
new oem water pump
new oem head gasket
arp head studs
aem fuel rail
gsr fuel regulator
greddy turbo timer
Former Moderator
Re: SO WHAT IS THIS WORTH THEN.. LOL... (jdmcivicturbo)
This is an outright for sale topic thinly veiled as a "what's it worth" topic.
Browse the market place, craigslist, etc. and guage the value.
If you want to PM me the other topic I'll lock it too.
See some people actually have an honest question about the value of a car they own, or ar looking to buy, and this forum would be the place to ask such a question.
In this case it's obvious that you're doing it just because someone else did it. Post this exact topic in the FS forums and add "testing waters" and/or "make offer" and see what you get.
