Question on Crank shaft bolt
I tried changing my timing belt and water pump this weekend that passed but i couldnt get the crank shaft bolt off. any suggestions?
Re: Question on Crank shaft bolt
impact
crank pulley tool |
That or chalk or flywheel With a large flathead screwdriver if those tools aren't available to you. No my first choice but it works
easy: crank pulley holder and a 3/4'' 3ft breaker bar made short work of mine with this combo.
I know O'reilly Auto Parts rents out the crankshaft pulley holder tool. Definitely a must if you do not have access to air tools.
its about 25$ for the holder, 60$ for huge ass breaker bar all in just over 80$ a lot cheaper then a shop would charge and you learn from the experience of it.
Took two 2x2" boards against crank/block on #1 and #4 journals with a 6 foot cheater to get mine to break.
Trying to hold flywheel teeth is a good way to bust some knuckles first class - but it can work. Oh and it is CCW - lefty loosey. |
I usually use a torch for those stubborn crank bolts. Just don't forget to replace the crank seal after that.
$60 for a breaker bar? You can get a Craftsman 1/2" breaker for like, $12, then slap as much lead pipe from your local hardware store as you can afford on the end of it. I have a 6 foot breaker bar for emergencies, sucker only cost me like, $20.
What is your year/make/model?
