Problem with Engine
Old Mar 22, 2003 | 03:44 PM
JC-aka-Wallabe's Avatar
Default Problem with Engine
I recently put a 97 LS Motor in my 99 Honda Civic Ex coupe. The car was a automatic at first now its a manaul transmission. The problem is the car won't crank or turn over its like its needs more power or so. I dont know what to do. I swap out the ECU with the 97 & 99 LS Manual ECU. I cant figure it out can anybody help me.
Old Mar 22, 2003 | 05:32 PM
degooser's Avatar
Default Re: Problem with Engine (JC-aka-Wallabe)
check your battery???
starter??
those could be the problem.....
thats all i can think of... oh and double check that your harness is hooked up right...like all the grounds and connections are on and so on..
Old Mar 22, 2003 | 05:38 PM
97hb's Avatar
Don't forget any of the grounds. Is it crankin or not crankin at all. Also check the ignition coil.
Old Mar 22, 2003 | 07:07 PM
Its like when you put the key in your own car and try to crank it up and it just cranks and cranks but doesnt turn over.
Old Mar 22, 2003 | 07:26 PM
degooser's Avatar
check you distributor...or check to see if you have spark..
take out a plug wire...hook up a plug to the end of the wire...hold it next to a ground in you engine bay...
crank...
there should be a visible arc coming from the plug to the ground...
also wear some heavy gloves so you wont shock yourself...
if not, then it is possibly your distributor...if you have a helms, you can check resistance on each of the different components of the dist..the ignitor(sp), coil....to see if you can pinpoint the exact problem....
I just had that same prob with my b18c...it was my distributor...no spark...i kinda took the easy way and bought a refurbished one...but hey theres a one year warranty on it so if it goes out.. im covered...
good luck!!
Old Mar 23, 2003 | 05:00 AM
dwnthehatch's Avatar
If i remember correctly there is a neutral safety switch you have to bypass from the auto trans. It's the switch that tells the car it is in neutral or park and it's safe to start. I hope this helps some.
carlos8
Jun 6, 2015 07:31 AM
Syke909
Sep 1, 2012 03:31 PM
Jazzy Jeff 978
Jun 25, 2009 10:50 PM
JC-aka-Wallabe
Mar 22, 2003 11:32 PM
JC-aka-Wallabe
Mar 22, 2003 06:52 PM
