Panel for left vent on 99 SI
Does anybody know if they make a replacment panel for the left air vent by the window where I would be able to cut it out to place a guage in?? https://honda-tech.com/forums/images...es/emsmile.gif
Re: Panel for left vent on 99 SI (vtecman)
that would be pretty easy to make
Re: Panel for left vent on 99 SI (Mar_EK)
Do you have any ideas on how to make it?
this is just off the top of my head, but...
get some plastic, or maybe even carbon fiber at http://www.raceplates.com trace the vent hole with onto some paper cut out the vent hole shape and draw it onto the underside of the material with a crayon. if you're using soft or thin plastic, you could probably cut it with some kind of clippers or scissors. carbon fiber would need a dremmel. after you cut it out, you could make a mounting bracket in the vent hole. maybe get some L-brackets or something from the hardware store. i dunno what it looks like in there so im not able to come up with a good way of setting it in. before you mount it, cut out where you want to put the gauge. also, if you want a more custom look, you could get some fiberglass at a hardware store and form it to be kind of like a dome thing or something, who knows. there are lots of different ways. |
sounds like a good plan. the gauge usually has it's own bracket to mount onto/behind whatever the material is, definately the hard part would be seeing how to mount the "gauge pod" so to speak.
