obd2a to obd2b conversion??
Old Dec 24, 2011 | 03:05 PM
oldskoolcool's Avatar
Default obd2a to obd2b conversion??
ok so I'm very very new to working on cars with an ecu. so here goes my issue.
i bought a 2000 civic hatchback (d16y7) car i believe it to be obd2b (someone told me) and i have put in a 1996 coupe d16y8 (obd2a) i used the wiring harness from the d16y7. and the ecu. but it will only crank over now. no fuel pump buzz..
the stock ecu for the d16y7 has 3 plug ins, 2 are off the engine harness and one plugs in from the harness that goes to the fuse panel under the hood then back under the dash.
the d16y8 has 3 ecu plugs but there all off the engine.. does this mean i need to change the fuse panel and all the dash wiring as well?
i bought this car cheap half swapped after being told it just needed to drop in plug in and drive away... "its my reliable car"
please give me some info thanks a lot for your help.
Old Dec 25, 2011 | 06:58 PM
Default Re: obd2a to obd2b conversion??
bump
Old Dec 25, 2011 | 08:06 PM
Wrona's Avatar
you need a obd2a to obd2b conversion harness
Old Dec 26, 2011 | 12:22 PM
thank you for your response. that will solve the issue of the wire that needs to go into the dash then?...
Thanks for your reply over the holidays, i was worryed no one would see this!
Old Dec 27, 2011 | 05:43 AM
kyden's Avatar
you need an obd2b to obd2a conversion harness. that will fix your ecu plug issue.
you still have to do a 3 wire to 2 wire iacv conversion, knock sensor, and vtec solenoid.
Old Dec 27, 2011 | 08:08 AM
so you get the 2b to 2a conversion and run the stock 2 b wires? how do yo unwire up the iacv and stuff? also in order to get the vtec to work you need to get a vtec ecu right. theres not something inside you can do to engage it is there?
Old Aug 4, 2016 | 07:21 PM
civic d series's Avatar
What all did you have to do I'm in the same boat I have a 1999 hatch DX it has a 98 ex motor engine harness and ecu. the fuel pump is wired to ignition car is just a hack job I just got it and I'm trying to do it rite so what all did you do to make your conversion work thank u I'm lost
10cjennings
K Series
Aug 31, 2013 10:28 AM
codymm1014
Aug 23, 2012 10:36 PM
kruthles
Feb 5, 2004 06:00 AM
JohnnyEF
Mar 25, 2002 10:01 AM
