no vtec engagement after cam install
first thing to do is see if the vtec is working just because you can hear it dont mean its not working, second make sure you have oil preasure, hook up a oil preasure gauge and check, third if you ripped apart the cylinder head did you make sure that the "O" ring in the center of the block was their or aligned good or worm out, you always replace them ALL THE TIME, just to be on the safe side you dont want to work double over a small mistake like that
hooked a gauge up and it has 25 psi hot at idle and 75 psi hot wide open throttle
Did you not read the 1st post by OP?
then i thought i could be the wiring or the vtec solenoid (tested the sloeniod on my buddys car, works) wiring is fine too aswell as my ecu. (running neptune)
Again....did you even read the VERY 1ST POST?
91integraLSVTEC
Jan 14, 2009 11:08 AM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
