No start until cel goes off
Gotta 92 civic that doesn't start until cel goes away and you hear the fuel pump prime
I changed the main relay under dash, recently changed fuel filter Was going to change pump but thought it was okay Any suggestions? Also most of my fuses inside cab are blown down to to box don't know if that's fully related( but to fix do I have to find entirely new fuse box??? Thank you for your feed back |
Re: No start until cel goes off
Originally Posted by Hondatechnoobi
(Post 50332668)
No codes tho
Cel doesn't stay on but it doesn't prevent me from starting the car until it fades |
Rephrase this
"Also most of my fuses inside cab are blown down to to box don't know if that's fully related( but to fix do I have to find entirely new fuse box?" Did everything melt or something? Did the fuses go out one by one and you didn't bother to replace it or did it all go out at once? Why has this not been taken care of? Are you waiting for a bigger catastrophe? |
Sorry yeah the fuses was just blown when I had checked
The car is a project more or less But I was wondering if I should replace the fuse box because there is no power in the terminals of the fuse box where each fuse is plugged into because I changed out all the fuses but still no power in the box |
(Post 50332668)
Is there a possible way to test ecu?
And do I just find a new fuse box for the cab and connect it ? Any major problems? |
No way to directly test the ECU. Can you borrow a known good one?
Nah just junk yard
