need check engine light codes !
does anyone have the check engine codes? or a website that i can go to?
Re: (SinsEvil666)
alright cool thanks for the help https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (lil danny)
your new, take a looka round and figure out where everything is, asking stupid questions when its a sticky at the top of the forum makes u look wii-tarted
0 ECU - Electronic Control Unit http://b16a2.kicks-ass.net/diy...0.gif
1 O2A - Oxygen sensor #1 http://b16a2.kicks-ass.net/diy...1.gif 2 O2B - Oxygen sensor #2 http://b16a2.kicks-ass.net/diy...2.gif 3 MAP - Manifold Absolute Pressure sensor http://b16a2.kicks-ass.net/diy...3.gif 4 CKP - Crank Position sensor http://b16a2.kicks-ass.net/diy...4.gif 5 MAP - Manifold Absolute Pressure sensor http://b16a2.kicks-ass.net/diy...5.gif 6 ECT - Engine Coolant Temp sensor http://b16a2.kicks-ass.net/diy...6.gif 7 TPS - Throttle Position Sensor http://b16a2.kicks-ass.net/diy...7.gif 8 TDC - Top Dead Centre sensor http://b16a2.kicks-ass.net/diy...8.gif 9 CYP - Cylinder Position sensor http://b16a2.kicks-ass.net/diy...9.gif 10 IAT - Intake Air Temperature sensor http://b16a2.kicks-ass.net/diy...0.gif 12 EGR - Exhaust Gas Recirculation lift valve http://b16a2.kicks-ass.net/diy...2.gif 13 BARO - atmospheric pressure sensor http://b16a2.kicks-ass.net/diy...3.gif 14 EACV - (IAC) - Electronic Air Control Valve http://b16a2.kicks-ass.net/diy...4.gif 15 IOS - Ignition Output Signal http://b16a2.kicks-ass.net/diy...5.gif 16 INJ - Fuel Injectors http://b16a2.kicks-ass.net/diy...6.gif 17 VSS - Vehicle Speed Sensor http://b16a2.kicks-ass.net/diy...7.gif 19 ATLC - Automatic Transmission Lockup Control Valve http://b16a2.kicks-ass.net/diy...9.gif 20 ELD - Electrical Load Detector http://b16a2.kicks-ass.net/diy...0.gif 21 VTS - VTEC Spool Solenoid http://b16a2.kicks-ass.net/diy...1.gif 22 VTP - VTEC Pressure valve http://b16a2.kicks-ass.net/diy...2.gif 23 KS - Knock sensor http://b16a2.kicks-ass.net/diy...3.gif 41 PO2H - Primary Oxygen Sensor Heater http://b16a2.kicks-ass.net/diy...1.gif 42 SO2H - Secondary Oxygen Sensor Heater http://b16a2.kicks-ass.net/diy...2.gif 43 FSS - Fuel Supply System http://b16a2.kicks-ass.net/diy...3.gif Enjoy Modified by Lukezen_27 at 8:08 AM 3/21/2008 |
