my rear disk conversation transformation
just thought I'd share with you guys my integra trailing arms that are going on my 97 civic coupe. start to finish pictures, I'm pretty proud of myself I'm 18 years old and did everything the right way, I'm trying not to cut any corners on my civic. tell me what you think!
https://cimg8.ibsrv.net/gimg/honda-t...858567bca7.jpg fresh from the junk yard, picked then up for $50 https://cimg0.ibsrv.net/gimg/honda-t...b0dff4ff4c.jpg back side of them from the junk yard https://cimg5.ibsrv.net/gimg/honda-t...0f8ca9815d.jpg apart and ready for sand blasting, burnt the bushings out in the middle of the day in my neighborhood 😊 https://cimg8.ibsrv.net/gimg/honda-t...ab5ba4616c.jpg new parts in, exciting!! https://cimg9.ibsrv.net/gimg/honda-t...861ce43dd6.jpg https://cimg7.ibsrv.net/gimg/honda-t...299f8c6f8a.jpg all sandblasted did it all in a night https://cimg0.ibsrv.net/gimg/honda-t...6fe0dab48d.jpg https://cimg5.ibsrv.net/gimg/honda-t...6173895da2.jpg https://cimg8.ibsrv.net/gimg/honda-t...471ec9888f.jpg got everything powder coated the same day for $75 got it all done locally https://cimg2.ibsrv.net/gimg/honda-t...322bb01552.jpg https://cimg4.ibsrv.net/gimg/honda-t...2f99e9d363.jpg https://cimg5.ibsrv.net/gimg/honda-t...f418de4eb7.jpg nice and shiny, like new ready for assembly https://cimg2.ibsrv.net/gimg/honda-t...115e84e6af.jpg fully assembled ready to bolt on, stoked on the whole restoration https://cimg7.ibsrv.net/gimg/honda-t...a1d6cf7c82.jpg |
Re: my rear disk conversation transformation
Damn, nicely done. Wish I knew someone who could sandblast and powder coat locally.
Looks really good. I should mention, many of the experts here at Honda-Tech always advise avoiding the solid poly bushings for the trailing arm bushing. That one bushing requires more give than solid poly bushings and you will find it doesn't work out well or long.
Looks like crap.
Very nicely done! I wish mine looked like that! |
I've heard it can cause binding, what's that all about??
Originally Posted by Freedo_Civegra
(Post 51916190)
Looks like crap.
thanks lol appreciate it Very nicely done! I wish mine looked like that! |
If you are doing a track only car, the solid bushings will net you better performance and track cars tend to be tore down and rebuilt consistently etc.
For street use with all the bumps, holes, uneven surfaces etc, the solid bushing doesn't provide enough flexibility for the trailing arm and the bushing tends to bind and possibly rip under the duress. I think to go poly on the trailing arm bushing for a daily driver/street machine you would need something like this: 081105B: Rear trailing arm mount bush - 400 - Rover Or even better, this: https://motoiq.com/project-dc2-integ...ith-whiteline/ You will have to scroll down a bit to get to the whiteline trailing arm bushing design. Also reading their explanation, the solid bushing isn't good for track use either, with steering issues binding etc. |
Well done youngster !!! It is obvious you are a car lover. Welcome to the fan club.
Looks awesome, dude! A rear disk swap is definitely on my list!
Looks great! Yeah on my RTSi when I got it the poly bushing the P.O. had installed were crumbling in place while it was parked! Granted I have no clue how long they were installed in there nor the quality but rubber certainly doesn't do that. I replaced with some aftermarket OEM-style rubber ones.
Originally Posted by deschlong
(Post 51917149)
Originally Posted by lonely_driver4
(Post 51917182)
I hope the energy suspension bushings do me good, I wanted to upgrade from OEM because my old ones were torn and my crv did the same thing, I'm more concerned about handling. I hope it makes an improvement, I've heard great things about them and bad. guess I'll find out in a couple months when I actually bolt them up.
Originally Posted by TomCat39
(Post 51916147)
Using ES bushing everywhere except the trailing arm bushing is what everyone says gives great performance.
The article of the DC2 build stated it messes up performance steering and causes binding. The binding is what I believe rips the bushing. It's the only bushings in the car you don't want a solid bushing. The design of the Rear Trailing Arm Lower Front Bushing is super critical when designing a performance part with less flex. This bushing needs to be stiff in the up and down and axial plane but have radial stiffness to control toe under side and braking loads. Some companies have solid bushings, but these cause severe bind, locking up the suspension and causing oversteer as well as a bad ride. Whiteline’s part has controlled compliance with 4 windows in the urethane to allow the suspension to articulate with a solid ring center to keep the alignment under control. This is one of the best bushing designs we have seen for the trailing arm. Previously, we have only recommended the OEM bushing in this location, but the Whiteline part should work well. |
(Post 51917275)
The article of the DC2 build stated it messes up performance steering and causes binding. The binding is what I believe rips the bushing. It's the only bushings in the car you don't want a solid bushing. |
Looks good!
Do you plan on changing out Master cylinder and proportioning valve? I know some models don't require the prop valve, but it's been a little bit since I've done mine, so I don't remember. Also you'll want the Civic SI e-brake lines if you don't have them already. |
Originally Posted by Ericjergs
(Post 51917830)
Looks good!
(Post 51917982)
yes I need ebrake lines still and i planned on doing a MC not sure what one would work best with my set up tho gotta do some research lol
JK though, looks fantastic! Keep up the good work! |
Originally Posted by black94sol
(Post 51918089)
wait wait wait...a newbie that does research?!?! Am I in an alternate universe?!?
(Post 51918287)
I try to learn as much as I can lol kinda hard to when your the only one in town that's actually into hondas, no lie lol their is one other guy in my town but hes not super friendly. I cant just ask him for advice without him being a dick about it and how his car is so much better bla bla bla.. you guys are all i got for help. any other advice on learning about Honda stuff? I have a couple books and I mainly just read alot of stuff on Honda tech super helpful so far..
(Post 51917982)
You’ll get a lot of different opinions on what to use. Going with the same size (not necessarily the exact one as it may not bolt up to your brake booster) as what your brakes came from can be a safe way to go. |
[QUOTE=Freedo_Civegra;51918338]Ive got a 1” ITR on mine, but I’ve got bigger brakes than I started with.
You’ll get a lot of different opinions on what to use. Going with the same size (not necessarily the exact one as it may not bolt up to your brake booster) as what your brakes came from can be a safe way to go.[/QUOTE do you know if I could use one for my civic off an integra? I have integra brakes on my civic so would it bolt up? if not what about a crv maybe? |
(Post 51918550)
do you know if I could use one for my civic off an integra? I have integra brakes on my civic so would it bolt up? if not what about a crv maybe? I think any 1998-2001 Integra master cylinder will bolt up to your booster. The ITR is the biggest, but the 15/16” would probably be fine, too. Others may want to give their thoughts. |
I ended up going with the Em1 master cylinder. It's a good feel and I can modulate pressure easily. If you get too big of a master for the brakes you have, I've heard you'll have a really stiff pedal with minimal travel. I wanna say the em1 is 7/8...I purchased whatever decent brand rockauto was selling under the em1 category.
EM1 7/8”? I think I’ve got one of those...
