my little f swap dilemma
going to explain in photos,
the dirty car http://i604.photobucket.com/albums/t...-11-04_932.jpg engine going in it http://i604.photobucket.com/albums/t...-05-19_214.jpg stock f23 post http://i604.photobucket.com/albums/t...-07-02_382.jpg stock f23 post with my hswap mount on it http://i604.photobucket.com/albums/t...-07-25_154.jpg h swap mount lined up with H22 post http://i604.photobucket.com/albums/t...-08-08_666.jpg h22 post on f23 block http://i604.photobucket.com/albums/t...-11-18_348.jpg if h22 post wont bolt to the f23 block, how do i f swap my car? |
Re: my little f swap dilemma
Will the OEM mount fit?
Would a F22 bracket work? Is it any different? I know a lot of people just do an H2B/F2B swap to eliminate most of the headache. Use B/D series mounts, the B trans, B linkage, B axles, B clutch. The only part that's a hassle is the header. |
solution= stick with B or D in a civic. Eliminates the headache all together
Originally Posted by NotAJDMFanBoy
(Post 44996710)
Originally Posted by mavvrik
(Post 44996732)
Well than ignore the comment and move on
But on a serious note, i thought you had to use H mounts. Could be wrong though |
(Post 44996780)
i dont know a lot about this swap but as far as i know its exactly like a H swap except one mount is deferent. Im not sure what mount to use but ive heard some reall effin horror stories about obtaining it
Im pretty sure hasport makes the mounts exactly for a F23 EG swap
(Post 44996842)
http://i604.photobucket.com/albums/t...-43-34_790.jpg |
Originally Posted by upgrayedd
(Post 44996765)
this has nothing to do with the trans. even if i was going f2b id still be having this issue.
I have somewhat of an interest in the weird things Honda did and solutions to these odd issues that arise. |
(Post 44996842)
Hasport H-mounts are the ones that fit i believe
Why not just use that H22 bracket you have on the F23 block...?
Originally Posted by hondamark35
(Post 45003610)
see photos |
Everything says the H22 mounts work. However I found this.
Originally Posted by high_revs
(Post 21645999)
...you need a 90-93 drivers side mount post...
(Post 45005806)
the bolt holes dont line up and the post hits the cam gear.
see photos |
Originally Posted by grumblemarc
(Post 45005901)
Everything says the H22 mounts work. However I found this. I'm assuming the post is from an Accord.
let us all know when you find out! this thread is helpful
contact greg at go autoworks, i belive he was making an adapret bracket for a h2d or somethnig like that, looked like what you need
Originally Posted by EK-ek
(Post 45009961)
(Post 45059890)
got it figured out, 90-93 accord bracket bolts right up, clears the cam gear, and takes the hmount.
http://i604.photobucket.com/albums/t...0-46-16_60.jpg |
sweet thanks man! how does it run?
