LS mtor swap
ok im looking to do a LS motor swap this summer and i need to knwo what parts i need to make it worki know the obvius things motor\tranny ecu. I need to know what all il need every littel bolt please help thanx in advance
Re: LS mtor swap (crazydude75927)
I'd be happy to help you out.
But what car you swapping into? |
guess i forgot that part its going into a 94 honda civic dx i have the ex vtec motor in it now powerfull but not enough i need MORE we always need more hugh oh well i apreciate your help
The torque on the ls makes daily driving much more enjoyable.
You'll just need to wire up knock sensor which goes to D3 pin out at the ECU.
What year B18 is it and what obd ecu you using? |
Re: LS mtor swap (poison)
um whatever my uncle can get at the time is what motor ill put in.
is knock sensor the only thing you have to wire in and do you have to do an obd harness. Once you wire in a new knock sensor what goes into the old ecu pin. Do you think it will be a whole lot quicker then a sohc vtec or just a littel. i was going to do a head swap on my sohc with bullfrog and put a 55 shot of nitrous then someone made me realize that for street fun an ls motor would give me more torque to play with im hoping to get into the fourteens with it ill have an ACT stage 2 clutch ready to drop in once i get the motor. |
You'll just need to wire up knock sensor which goes to D3 pin out at the ECU. What year B18 is it and what obd ecu you using? |
Re: LS mtor swap (HybridHackBatch)
but i could be wrong
You'll just need to wire up knock sensor which goes to D3 pin out at the ECU. What year B18 is it and what obd ecu you using? i dont remember doing that. if you go with an obd1 ecu it should be plug and play but with the p28 there was no code good luck with the swap |
