How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch?
basically went by the local junkyard today and they had a 90-93 integra with rear disk so im going back tommorrow to pull it off since it only costs $60 bucks for the rear disk conversion and was wondering how to take of the e brake cables since i will need them to swap the rear disk on my 93 VX hatch.
i think the prop. valve is gone but on that one DA but there is another DA there(rear disk is already gone off the 2nd one) and i didnt check that so i should be able to get the prop valve and maybe even upgrade to the BB and MS of the DA. tried searching too.... thanks https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch? (nyhustla2k)
remove the console. under the e brake there is two cables un hook those. there should be 2 10mm bolts. take those off. go under the car and the e brake cables should be run under the heat sheilds. take the heat sheilds off and unbolt the bolts that hold the cables to the body. then you are done https://honda-tech.com/forums/images/smilies/emthup.gif
Re: How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch? (bottle fed)
sounds good to me, thanks, just needed an idea of how difficult it was. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
