Help with mini-me swap
I have a D15B7 95 hatch, and have been given a 97 D16Y8 engine with bad bottom end.
I am thinking about putting the head on my 1.5 engine. Every thread I read leaves some info out or gives different parts. Can I do the swap and still have close to stock compression so as to buy regular gas. Also, which cam gear and belt really works right. I'm looking for a little more power with the same reliabilty and be able to run regular gas. Any help would be great. |
Re: Help with mini-me swap
You will be able to run regular gas with the swap.
I've read that the Z6 head gasket is thicker than the Y8. I guess that's the one to use.
Any opinions on timing belt and cam gear? Anyone? |
