Help with CEL 3, map sensor
I just finished swapping out my z6 with the jdm d15b7...everything ran fine for a while and then the CEL came on with a code 3...i tried using a sensor off another d15b7 and my z6...but no luck...all vacuum line seem okay and know don't know what else to do...help! https://honda-tech.com/forums/images/smilies/emsad.gif
Re: Help with CEL 3, map sensor (lilobusta)
I am also having map sensor problems mine is toast. on your d15b7 does it go on the intake manifold, or on the firewall? I have a d15 map sensor, from my old engine, ill trade ya for your z6 one. also are you clearing your ecu? under your hood there is a fuse box , pull the 7.5 amp fuse closest to the firewall this will clear your codes
Modified by sonicivic at 10:22 AM 8/9/2004 |
Are you boosted? Boost is the number 1 reason to throw the map sensor off.
Re: Help with CEL 3, map sensor (Luserkid)
Luserkid...Nope no boost...thats how i blew my z6 https://honda-tech.com/forums/images...s/emsmilep.gif
sonicivic...i've tried other d15b7 sensors and still getting the cell and it goes on the manifold |
check all vacuums and connect it directly to the nipple on the throttle body. resey ecu after each try
Re: (Andres-eh2)
Did you reset your ecu after you swaped the sensor? If not try that with the B7 sensor in it.
Re: (Luserkid)
Yeah i did reset the ecu(unplug neg. for like 30 sec...right?) and all vacuum are on tight...i'll double check though...
yup all vacuum lines are tight...what else? anyone?
before when i had the map code going off i would reset ecu for 30 seconds, nothing. dont know if it makes a difference but it worked after i unplugged the postive for 15 minutes
Re: (Andres-eh2)
i'll have to try that in the morn. https://honda-tech.com/forums/images/smilies/emthup.gif
