Help on b16 block stamp
Are all b16a2 block stamps smaller then the b16 stamps? I was told I purchased a b16a2 block and the owner shaved the 2 off the end of the b16a2 ( vin was ran and its not stolen) It looks like the stamp on the b16a2 block I thought I bought is larger then on the b16a2 block I have with a bent rod. If it is a b16a block and not a b16a2 do I just need to swap over the oil pump for it to all work in my obd2 99 civic si?
Thanks |
no there the same size
Originally Posted by iwanttokillgod
(Post 36642142)
Ok, i'm somewhat confused. You think you bought a USDM B16A2, and the block says B16A, because the owner shaved off the 2? Ok, The only reason I could think of for shaving off the 2 is trying to sucker someone into thinking its a JDM engine, theres really no other reason to it, even if it was stolen it wouldn't help you. Either the guy really did shave the 2 or its a JDM B16A. Next point, you say you ran the VIN, JDM engines don't have a VIN, but they do have the holes to rivet the VIN tags on, maybe he put his tags on it. Next point, oil pump. JDM engines do not have a CKF sensor, USDM OBD2 engines do. If it has a CKF sensor (sensor mounted to the oil pump) its at the very least got a USDM B16A2 oil pump, or more likely its USDM B16A2.
why would this block I purchased have a larger stamp on it, compared to the b16a2 block that was removed from my car?
Originally Posted by 94EG8
(Post 36642970)
Originally Posted by BoostedH
(Post 36643014)
(Post 36643014)
Ill take a look to see if I did plug the ckf sensor in. Is that the sensor right behind the crank pully?
