HELP ASAP!
im building my engine back up, and when torquing my main seal back down (9ftlbs) 2 bolts snapped..
IM SUPER PISSED. do you think its okay if i have to bolts broken holding the main seal on? its got liquid gasket all the way down and its fairly tight on there. or do you think i should dis-assemble everything and get the machine shop to take the snapped bolts out.. HELP! PISSED OFF! http://members.shaw.ca/sivic/broken1.JPG http://members.shaw.ca/sivic/broken2.JPG |
Re: HELP ASAP! (JDMPROject)
damn,,, do it right and disassemble and have the machine shop take it out. because when ever you want to push the engine your always going to wonder if its going to leak from the main seal. which means pulling the trans , clutch, etc off to see if thats the problem.
thats what i would do.. |
were you using an inch or ftlb meter? most ftlb torque wrenches arent accurate that low.
and i would take it to the machine shop, no point fucking it up more. |
Re: HELP ASAP! (Kamin)
yeah thats what i figured. it didn't seem accurate.. just kept turning.. POS..
so i should just take it and get them drilled and re-threaded? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMPROject »</TD></TR><TR><TD CLASS="quote">yeah thats what i figured. it didn't seem accurate.. just kept turning.. POS..
so i should just take it and get them drilled and re-threaded?</TD></TR></TABLE> not sure if 9lbs is the correct torque, but if the book says that then ok, just hand tighten it. 9lbs is not that tight anyway, hand tight then just alittle more should be sufficient. you might also see if your dealership will helicoil it for you. i had a 68 dodge charger with a 454 hemi. that i stripped an engine bolt, and they were able to helicoil it. just look at all options you have. |
i did the same thing. lol. if you have the time, get it removed and replace with a new bolt, but i think you will be ok.
Re: HELP ASAP! (shraz)
i wanted to be safe, so i just dropped the block off at the machine shop, and ordered new bolts...
so that lil problem set me back 2 days(waiting for new bolts to arrive) http://images.honda-tech.com/set1//smile/emcrook.gif thanks for the help guys https://honda-tech.com/forums/images...es/emsmile.gif Modified by D16BEYOTCH! at 12:56 AM 7/27/2004 |
