Heat and Idle issue
This is what i have that is the motor
1995 Civic EX (D16Z) JRSC (9lbs boost) JRSC Fuel Pump JRSC Fuel Pressure regulator AEM Intake (NEW) MSD 6 With boost retard MSD wires V-AFC Gude Throttle Body ACT Clutch w/ Flywheel 99 Civic Headers This is what i have replaced in the past week. Radiator Radiator cap Timing belt super charger belt power steering belt Honda Metal head gasket Honda water pump Cap& rotor Denso Plugs Injectors (stock) Fuel rail (stock) AEM Intake Thermostat (170 degrees) 02 Sensor New oil change Coolant flush IACV With all these things replaced I still have a odd idle speed when at a complete stop about 1500 rpm if i hit the gas real qwick it will idle at 900 rpm. still to high i should be 650-750 rpm. ISSUE 1 When i get on the freeway and boost it reall qwick it will idle really high when i put it in Nuetral @ 4000 RPM and i have to down shift to get it down from that. Issue 2 I also have a cooling issue as well. The issue being it will heat up a past way past 210 Degress then i will have to turn on the heat to disipate it. We did a correct 50/50 mix and let it sit to get air out of the lines. Also hiiked a pressure tester to the coolant system it help like a champ @ 17lbs Issue 3 Air/Fuel Replaced the O2 Sensor and my gauge says that i am runnig all the way lean doesnt even read at all. When i do start from the morning at a cold start it will go up but only half way sometimes more but a mile down the road it drops Big time all the way so it doesn not read. I have tried 3 O2 sensors and all the same senario and i know the gauge is right because my car runs like poo with no fuel. There have been a couple and i do mean a couple of times it went all rich and pulled like a scared puppy https://honda-tech.com/forums/images...es/emsmile.gif So i am at a losing point and cannot think of anything can someone help ? Thanks in advance. Any suggestions would GREATLY appreciated Modified by hondaman2 at 12:08 PM 8/8/2004 |
Re: Heat and Idle issue (hondaman2)
anyone have anything ? Please https://honda-tech.com/forums/images...es/emsmile.gif
