Ground controls
I bought some used gcs two days ago with ek struts and i need help identifying the spring rates
Rear 180.64.44 Front 200.64.58.What would you suggest i put up front and back and back of my eg and are koni yellows a direct bolt-on? |
Re: Ground controls (spoonef)
i'm guessing you're talking about the sleeve coilovers...if i remember correctly, there's some special GCs for the konis.... check http://www.prostreetonline.com and check part numbers. the ones for koni yellows were like 330 or something. hope that helps
Re: Ground controls (SD350z)
Yep, Ground Control's are different for Koni's.
Re: Ground controls (Hondaddict)
Is there any modifications involved when fitting koni yellows onto gcs?
bump
you hav to get a certian set of GC for Konis https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Ground controls (jdm98hb)
So you're not selling them anymore?
Re: Ground controls (chowmien)
I think you need to call them http://www.ground-control.com/
there answer I believe will be better than the ones here IT they can sell you an adapter or exchange ect otherwise I believe you can mod the konis but contact them first |
stiffer springs in the front
