Engine stopped on highway (solid cel)
Old May 15, 2010 | 05:32 PM
Linked's Avatar
Default Engine stopped on highway (solid cel)
On the way home from a 300 mile road trip. About 250 miles out my engine stopped. I checked for spark and didn't have spark.
I narrowed it down to two causes:
my dizzy finally took a splat
or m timing belt broke while driving and bent a valve. And won't spin the cam which is why I'm not getting spark when I check
you guys ideas? I'm still out here stranded typing on my phone
thanks all.
Old May 15, 2010 | 10:43 PM
Linked's Avatar
Default Re: Engine stopped on highway (solid cel)
Bump, got home and had to push the damn car intoa nearby gas station
found an old thread saying that a Solid CEL can be caused by a main relay, or the ECU
i guess im gonna have to get AAA and get the car towed back home
Old May 16, 2010 | 04:59 AM
EK2.0's Avatar
A solid CEL just means you have a code stored. Until you pull the code and figure out what the code is related to the Check Engine Light is just that, a LIGHT.
Old May 16, 2010 | 08:40 AM
Linked's Avatar
BUT, when i attempt to jump the 2 pin connector to check the light, it doesnt blink, it stays solidly lit
thats what i meant
Old May 16, 2010 | 09:30 AM
Jimmy's Avatar
Global Moderator
I had a similar problem about two years ago with my chipped ecu, somehow how the .bin file on the chip had corrupted it's self and went bad.
I replaced it and viola my problem was solved..
See if you can try another ECU out.
GL!
Old May 16, 2010 | 11:20 AM
Linked's Avatar
my ecu is stock, not chipped,
the only thing i have done to it is a manual swap, cut rp17 and bridge rp18, cant remember which.
did that about 8 months ago,
ph0shizzle
May 13, 2006 08:36 PM
99IntegraGS
May 3, 2004 07:18 AM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
johnzm
Sep 13, 2002 02:39 PM
