engine code P420
Old May 31, 2006 | 09:56 PM
ironryder's Avatar
Default engine code P420
anyone gotten this code before? i got a 98 civic EX with only 60,000 miles. i have already replace upper and lower o2 sensor.it gone away for a few months but is back again,so whats next the cat? and if so,what is the most common problem that would kill the cat?
thanks
Old May 31, 2006 | 09:59 PM
thehatchninja's Avatar
I think that's primary 02.
Old May 31, 2006 | 10:00 PM
sol2hatch's Avatar
Default Re: engine code P420 (ironryder)
if you run rich, then that will blow your cat
Old Jun 3, 2006 | 07:39 PM
ironryder's Avatar
can dirty injector cause you to run rich?
Old Jun 3, 2006 | 08:06 PM
LVB18Civic's Avatar
Default Re: (ironryder)
We see this all the time at work. That codes means that the cat. is no longer efficent. You need to replace your cat. then clear the code.
Old Jun 3, 2006 | 09:06 PM
johnny_tdi's Avatar
Default Re: (LVB18Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic &raquo;</TD></TR><TR><TD CLASS="quote">We see this all the time at work. That codes means that the cat. is no longer efficent. You need to replace your cat. then clear the code.</TD></TR></TABLE>
second this
Old Jun 3, 2006 | 09:09 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
i third this same thing happen to my friend and we put a carsound cat on and it went away after we cleared the code
jc007i
Jan 23, 2012 12:29 AM
Flux
Jan 29, 2005 11:22 AM
Two_K Si
Oct 13, 2004 08:32 PM
R-Rated
May 20, 2002 11:48 AM
DelsolVtec18
Sep 4, 2001 11:51 PM
