ej1 with b20 won't start
ok i got a ej1 wit a b20 swap cranks over but no start, changed ignition module still nothin changed to obd2 distributor wit obd1 ignition module new plugs but crank over no start or no spark...
any ideas... |
Re: ej1 wit b20 wont start
Grounds!
Is there spark? Fuel pump working and injectors spraying? Timing correct?
no spark, its weird cuz i just drove it home, put in some sub s and amps then all of a sudden no spark or nothin, three hours earlier it was runnin perfect. i went to thhis auto store in sac, they replaced my ignition module twicve but still no spark or nothin tested to see if there was power goin to the distributor and there is so he threw me a obd2 distributor i spliced the wires so harnesses plugged in and put the obd1 ignition module in it and still nada!:mad:
Re: ej1 with b20 won't start
Does the fuel pump prime?
Any CEL codes? |
u neeed a obd1 distributor on obd1 motor the injector pulses and everything are different.. chances are if u have no spark it would be something in the distributor, had same prob with a dc4 changed coil, and a few other pieces in dizzy and turned out it was bad.. autozone had it in stock for 200 cash .. lifetime warranty but u still need a cap and rotor
sorry for winded post hope it helps |
yeah imma just say f*ck it and go get a new one instead of tryin used ones...
thanks bro |
Originally Posted by RonJ@HT
(Post 44063232)
Any CEL codes? |
