ECU HELP
i have a 95 civic hatch with a GSR swap i also have a t3/t4 turbo kit with 450cc inj. i have every thing i need for the turbo install but now i need to know what ECU i need to use. i'm going to run about 12-18 PSI will my stock ECU handle that or do i need to chang it. any info will help thanx
Re: ECU HELP (peck1005)
Stock ECU will not work
You need something that is chipped. Contact either http://www.xenocron.com or http://www.phearable.net/ and they can help you out with buying one |
You car will run fine with what ever ECU you are running now as long as the turbo kit is installed properly. If you plan on running up to 18 lbs then you will want to get some sort of standalone ECU management. I am partial to Hondata but there are others out there. Check out the forced induction forum on this site for more information.
Re: ECU HELP (VTEC-DA)
I have a question for you. I have a ECU that i was told came out of a 96 model civic how do you check to see if its for a 96 or a different year. They said it was for a single over head cam vtec will it work on a 92 honda with a D15B single over cam VTEC?
Re: ECU HELP (SkoundrelUSA)
Re: ECU HELP (chris92civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris92civic »</TD></TR><TR><TD CLASS="quote">I have a question for you. I have a ECU that i was told came out of a 96 model civic how do you check to see if its for a 96 or a different year. They said it was for a single over head cam vtec will it work on a 92 honda with a D15B single over cam VTEC?</TD></TR></TABLE>
I don't know how to tell what specific year it came from, but if the sticker on the ECU says something like 37820-P2E-A02 its from a 96-00 DX/CX If its something like: 37820-P2P-A01 Its from a 96-00 EX. Neither ECU will plug into a 92 Civic without a conversion harness. And it prob not run correctly and throw a check engine light. If you got a JDM D15B in your car, look for a P28 |
