Difference in GSR and SI wiring harness in EK coupe
I am in need of a wiring harness as I've read for a b series conversion into an EK coupe, I was wondering if there is any difference in a wiring harness for the 99-00 si and using one for a GSR..
My original harness did not plug up to the dizzy and there is a different crank connector on the motor and in the harness... If someone could assist me, I might be able to locate a GSR harness easier then an si harness |
Re: Difference in GSR and SI wiring harness in EK coupe
What year and model is your car? EK doesn't help a lot.
What engine are you trying to use? You CANNOT use a Integra harness with out a lot of cutting and splicing to make it work. 94-01 integra's all run a 2 peice harness, where 96-00 civic's run a 1 peice harness. You can use a SI harness, however if you have a 96-98 civic it will not be a direct plug and play. If you have a 99-00 it will work. |
you can also use a ex harness if its a 96-98... i think the 99-00 ex is diff than the 99-00 si if you have a 99
^^he's right. the 99-00 harness has a different distributor clip. in other words, u can't use the GSR harness without heavy modification.
Just reuse your harness and add the additional wiring: VTEC solenoid, VTEC pressure switch, knock sensor, extend primary O2, 3 wire IACV to 2 wire connector, match the colors on the crank sensor
Originally Posted by HondaPartsHero
(Post 44710261)
on my 97 Ek u just used a 96-98 ex harness and everything plugged in fine... and to the op if you have a coupe its not a EK, its either a EJ 96-98 or EM 99-00 hatchbacks are EK's ;-)
Originally Posted by ReDHaTcHyGuy
(Post 44712644)
The only exception are the 99-00 si and those were em1's. Hathback's are not any more of a EK then coupes are. |
