d15z1 turbo?!?!?
im thinking of turboing a vx hatch but i have a few questions first?... what kind of fuel management is offered for this motor? will crome or uberdata work with this ecu??? ive herd bad and good things about the d15z1 but i think it will be a fun little project. ive searched but cany find much on turboing these engines??? does anyone have sucess with these. pics would be great!!!
-thanks |
Re: d15z1 turbo?!?!? (90efSI)
try the FI motor FAQ im pretty sure its possible search it
Re: d15z1 turbo?!?!? (TypeRobert)
yo i got a vx turbo it accually runs pretty smooth seeing as it has no ems on it at all not even an afc but but if ur planning on doing it u should build it cause its not fast at all
Re: d15z1 turbo?!?!? (lambertincorp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lambertincorp »</TD></TR><TR><TD CLASS="quote">yo i got a vx turbo it accually runs pretty smooth seeing as it has no ems on it at all not even an afc but but if ur planning on doing it u should build it cause its not fast at all
</TD></TR></TABLE> maybe thats because you dont have a good tune. to the OP: search around the FI forum and maybe talk to Bense, he pretty much wrote the book on vtec-e performance https://honda-tech.com/forums/images/smilies/emthup.gif . |
schardbody knows a lot about turboing a bone stock d15z1
Re: d15z1 turbo?!?!? (knockout)
this is very true but it is getting built as soon as i blow it up, but with a tune now it would be able to keep up with stock gsr's and civic si's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lambertincorp »</TD></TR><TR><TD CLASS="quote">this is very true but it is getting built as soon as i blow it up, but with a tune now it would be able to keep up with stock gsr's and civic si's</TD></TR></TABLE>
Probably beat them unless you suck at driving. Boost the hell out of it. |
I doubt it with that trans. |
Re: d15z1 turbo?!?!? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">I doubt it with that trans. </TD></TR></TABLE>
True, take care of that matter and you are good to go. |
Re: d15z1 turbo?!?!? (cambopheonix56)
D15Z1 3.250 1.761 1.066 0.853 0.702 3.153 3.250
D16Z6 3.250 1.900 1.250 0.909 0.750 3.153 4.250 Get an EX/SI transmission. |
Get a stand alone like the EMS, new tranny, and keep the boost around 6-7 psi to be safe. I'm not sure about those injectors either. I know on the 96+ Civics, the non-VTEC injectors (and the Y5 injectors) are smaller.
Re: d15z1 turbo?!?!? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">and keep the boost around 6-7 psi to be safe.</TD></TR></TABLE>
How can you say that when you don't know what turbo he is running? Boost means nothing, its how much power the motor can handle https://honda-tech.com/forums/images/smilies/emwink.gif |
i have slightly bigger injectors and its quick the trans is rough in high rpm but it still can keep up with the grs's and si's when it doesnt lag, with the setup i have and i have been running 9 psi all day for 5000 miles with no problems
