Could i hard wire my VSS signal going to the ecu to a constant power source?
long story short,
i didnt do the wiring/swap on this car im very short on time for a big event throwing code 17 vss, could be the vss,maybe the cluster, could be the wiring, ive been trying all day to figure it out, nothing my question is can i feed the vss a constant power source as to trick the ecu into thinking its getting a signal? greater than 20mph? that way vtec and no code? i mean the vss really has no role in the fuel maps it just controls vtec and speedo readout. i just dont want to feed it too much power and blow the ecu? what do you think? |
Re: Could i hard wire my VSS signal going to the ecu to a constant power source? (.Keyser Soze)
p.s. this would be a temp fix obviously
No the speed sensor sends out pulses if I understand correctly and a constant voltage would burn out the ecu or give you the same code.
Re: Could i hard wire my VSS signal going to the ecu to a constant power source? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">No the speed sensor sends out pulses if I understand correctly and a constant voltage would burn out the ecu or give you the same code.</TD></TR></TABLE>
i was afraid of this anyone know if you can tune around this in crome or uber? i know u can disable the vtec speed check but is there any way to get the ECU to ignore the vss entirely??? |
How about just fixing it? It can't be that hard, power ground and signal. Take it off, Turn the gear and see if it puts out a signal. Go to the ECU harness and see of the signal's getting there. Make sure it's got power and ground.
