Compression Ratio Question for EX
how do i mess with the compression ratio for Civic 99 EX?
I want to increase it |
Re: Compression Ratio Question for EX (mushu315)
well other than buying higher comp. pistons which is the best way to increase compression. you can also get a thinner head gasket or mill the head which i recomend not doing b/c not many shops will do a great job on that.
Re: Compression Ratio Question for EX (boosted eg)
Some D16A6 pistons would be a good idea, and maybe milling the head a little bit https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Compression Ratio Question for EX (BauleyCivic)
just the pistons will do? or do i need rods too?
how do i know if the ring is worn down and needs replacement? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mushu315 »</TD></TR><TR><TD CLASS="quote">just the pistons will do? or do i need rods too?
how do i know if the ring is worn down and needs replacement?</TD></TR></TABLE> Uhh...do you have any idea what you're talking about? |
no, that's why i'm asking
Just replace the pistons u shouldnt really hafta replace the rods unless u really want to but yours should hold up well... But for higher compression take ur metal gasket and remove the middle layer then u get a thinner headgasket thats the cheapest way to go unless u go n buy a thinner headgasket. But basically pistons to raise the compression and some of the other stuff that people here already suggested.
