Check Engine Light on problems....
i just bought a civic and the check engine light comes on AFTER YOU DRIVE IT FOR A WHILE....i did the check engine code and the code is 43 Fuel Supply System....what does that mean....please let me know what it is if you know...thanks... https://honda-tech.com/forums/images/smilies/emsad.gif
I would do a check of your fuel pressure. Pump might be going bad, or FPR could be going bad or filter could be getting clogged.
Might sound funny but does it have a gas cap? check and see if its tight.
Re: (upgraded)
thanks for the tip...i'll try it and see if it helps.....
Re: Check Engine Light on problems.... (civic_boi)
Code 43 usually means the O2 Sensor is lazy. So I suggest U change it. Had the code yesterday on mine. New O2 sensor and i'm fine.
O2 Sensor - $168 (Aftermarket::Not Universal) O2 Sensor - $250 (Dealer) B16A2 |
| All times are GMT -8. The time now is 04:08 PM. |
