check engine code..
Old Feb 23, 2010 | 02:40 PM
jdmeg6honda's Avatar
Icon6 check engine code..
im a newbie here this is my first post my car failed smog its a 93 civic coupe dx bone stock . and me being a dumb *** and didnt think about checking my timming and it was off and the value was loose also but now i adjusted the value and set the timmimg correct and i just did a seafoam on the brake booster and crank case and i diagnostic the car the check engine light stays on with no flash?
Old Feb 23, 2010 | 04:00 PM
junk95civ's Avatar
Default Re: check engine code..
Know how to check your CEL?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ecu-codes-everyone-682412/
Old Feb 23, 2010 | 04:53 PM
eros18's Avatar
no flash at all?
thats weird.
Old Feb 23, 2010 | 05:04 PM
junk95civ's Avatar
Hes probably not jumping it and just looking at it while its on.
Old Feb 23, 2010 | 06:40 PM
jcdimvic's Avatar
must jump the connector
Old Feb 24, 2010 | 04:54 PM
i use the jumper but thats the code .b4 i unplug the battery i use to get code 43 but now its just no flash..
Old Feb 26, 2010 | 03:31 PM
rhdej2's Avatar
bad ecu?
Old Feb 26, 2010 | 05:13 PM
junk95civ's Avatar
Try reseting the ECU "properly" theres different ways to do it, but I did the one where you dont touch the battery but only the fuse. I was getting a solid light, freaked out and searched the hell out of it, reset my ecu, and it dissappeared. So reset your ecu before you continue freaking out. Other than that I found out that its probably a bad ecu.
Old Mar 2, 2010 | 08:49 PM
i just tried another ecu from another car i also tried the fuse rest thing still no luck
Old Mar 3, 2010 | 09:35 AM
junk95civ's Avatar
No luck? What do you mean by that? And what ECU did you use and how did you do the reset?
Old Mar 3, 2010 | 09:39 AM
rhdej2's Avatar
not tryin to be a dick or knock your knowledge but there's gotta be somethin you're doin wrong?
Old Mar 4, 2010 | 09:08 AM
ok so far i use paper clip to jump the diagnosis plug located under the glove box on the right side the 2 wire one and yes i did it rite because when i plug it up the check engine lights come on and when i unplugged it the lights goes off i know this because last month i did it and code 43 came up. and i reset the car battery by leaving it off for a whole hour with the ecu unplug and ecu fuse unplugged . and i tried just by unplugging the battery by it self for 30 min and. then another way is when i unplug the ecu fuse for 15 min and another way just by unpluging the ecu . i have tried another ecu from my brother car and his ecu works fine because i diagnosis his car and it works.. ok im runing out of idea because i have heard people say use another ecu .rest the ecu fuse un plug battery but i dont know what else to do my car drives ok but it feels like i have vtec but my car dont have vtec the reason i said that because when i drive it start 2 get faster at higher rpm like vtec and i just did full tune up and i just passed smog so new everything
rhdins
Jun 11, 2008 10:13 AM
HATCHFIEN
Nov 1, 2004 10:00 PM
GeorgeY
Jun 29, 2003 08:59 AM
BigMig
May 10, 2003 06:01 PM
type Gendy
Apr 21, 2003 04:48 PM
