Changing gas?
Is there anything i should do before i change from 87 octane to 89?
Re: Changing gas? (spoonef)
no..if you have a d-seires i wouldn't advise using anything higher than 87. unless you have a fire breathing DOHC.
Re: Changing gas? (NerveAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NerveAgent »</TD></TR><TR><TD CLASS="quote">no..if you have a d-seires i wouldn't advise using anything higher than 87. unless you have a fire breathing DOHC.</TD></TR></TABLE>
a mini me will require a higher octane if thats what hes doing |
You should probably tear down the entire motor, drop the tank, and completely clean everything of every last bit of fuel, otherwise the two octanes will mix and cause a fiery explosion that will destroy y0 Vt3CuLar capabilites. https://honda-tech.com/forums/images...s/emsmileo.gif
Jk! https://honda-tech.com/forums/images...es/emsmile.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonef »</TD></TR><TR><TD CLASS="quote">Is there anything i should do before i change from 87 octane to 89?</TD></TR></TABLE>
why not use 91? |
Re: Changing gas? (peshte)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peshte »</TD></TR><TR><TD CLASS="quote">why not use 91?</TD></TR></TABLE>
Re: Changing gas? (BS 22)
Yeah the price of gas has made me drop down from 91 to 87 , & i'm running a Mini-Me https://honda-tech.com/forums/images...s/emsmilep.gif . Damn High Compression , well i've been running on 87 for 2-3 weeks so far with no signs of detonation so I guess i'll just continue to use 87 https://honda-tech.com/forums/images/smilies/emwink.gif
