A/C puts out a weird smell
For the pass few days after my A/C has been running for about 5 minutes it starts to put out this smell that smells like moldey water. Does anybody know what it could be?
TIA |
Re: A/C puts out a weird smell (skrewdriver88)
Bump
molds can grow inside ur ducts due to moisture when using ur a/c
best way to prevent the smell is to blow out ur a/c off 5 minutes after arriving at a specific destination. works great! |
im sorry that's before!
Re: A/C puts out a weird smell (cvccjdm)
Thanks. Would it help if I took off the vents and cleaned inside of them. Do they just snap out? The air vents im talking about
that shouldn't be necessary. what i commonly do besides running it w/out a/c is to turn on the heater to dissipate the moisture. might wanna try that instead of removing ur ducts. the disadvantage of that is mold will grow again after cleaning ur ducts.
open up the evaporator and clean it. also your blower might be dirty as well. clean up the mess and see if that helps.
god i hate that smell https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (Hatchtrap)
its just smelly ? nothing is leaking on the floor ?
Re: A/C puts out a weird smell (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">open up the evaporator and clean it. also your blower might be dirty as well. clean up the mess and see if that helps. </TD></TR></TABLE>
This would be my guess, or you can buy a can of stuff that dries it out. Bad part is, you either have to take the assembly apart or drill a hole in it and spray that way. But if you're pulling it apart, you might as well give it a thorough cleaning |
Re: A/C puts out a weird smell (hatchling37)
You didnt' just get a new R12 charge did you?
When you wash your car, try to put the a/c off then put in HOT for about 20 min, then put inside your car a pot with bleach CLORO in spanish and close the door and keep it there for others 20 min. The heat and the bleach will kill everything.
Re: A/C puts out a weird smell (Leviata-N)
Were is the blower located at? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy del sol »</TD></TR><TR><TD CLASS="quote">its just smelly ? nothing is leaking on the floor ?</TD></TR></TABLE> Correct its just the smell.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx »</TD></TR><TR><TD CLASS="quote">You didnt' just get a new R12 charge did you?</TD></TR></TABLE> I didn't get a new R12 |
bump
Do this.. get a can of lysol ( scented to your liking) then turn on the blower with AC then take that can of lysol and look underneath your glovebox and you will see some kind of inlet vent, sort of like a screen with bigger holes on the right corner)
Make sure you select re-cycle air option ( button will be yellow) now take your lysol and spray inside that hole little by little. After you do that for a few min then turn off your ac and wait a few hours. Lysol kills germs and mold and that should make your AC smell better after a few weeks ,, it will smell like the scent you used for a few hours and I suggest you not to go inside the car for awhile. |
they say by turning off your a/c compressor before you arrive at your destination you can prevent the smell...
Re: A/C puts out a weird smell (mMmdoOonut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mMmdoOonut »</TD></TR><TR><TD CLASS="quote">they say by turning off your a/c compressor before you arrive at your destination you can prevent the smell...</TD></TR></TABLE>
well what happens is that the AC is a collector of moisture , thats why you use it on the defroster for the windshield, so after you turn off the car the moisture is still there so you need to turn off the AC then run your fan for a few min if possible. |
Re: A/C puts out a weird smell (BatuKing)
Check and make sure your drain is clear!
Re: A/C puts out a weird smell (pon55)
Where is the drain at?
at the firewall near the passenger footwell.
Re: A/C puts out a weird smell (xEnderx)
OK, Im having this same problem... just got a new R12 charge and the car smells like I whacked a small army of skunks. Any idea what the problem is? c'mon guys... my car stinks and I *gasp* used the search button!https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: A/C puts out a weird smell (Miguel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miguel »</TD></TR><TR><TD CLASS="quote">
OK, Im having this same problem... just got a new R12 charge and the car smells like I whacked a small army of skunks. Any idea what the problem is? c'mon guys... my car stinks and I *gasp* used the search button!https://honda-tech.com/forums/images...s/emsmilep.gif</TD></TR></TABLE> If you just charged your system and let the evaporator sitting in your car for awhile do the lysol trick to get it out.. You have alot of mildew on it and thats what's causing the smell |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">If you just charged your system and let the evaporator sitting in your car for awhile do the lysol trick to get it out.. You have alot of mildew on it and thats what's causing the smell</TD></TR></TABLE>
Hmmm... makes sense. The smell just became noticeable after a few days of hard rain here in Toronto. Is the Lysol trick a permanent solution though or will I have to repeat this every so often?? |
Hmmm... makes sense. The smell just became noticeable after a few days of hard rain here in Toronto. Is the Lysol trick a permanent solution though or will I have to repeat this every so often??</TD></TR></TABLE> Should get rid of most of it , it all depends on how much mildew has accumulated over the evaporator box area. |
