Brake light in dash stays on??? HE:P!!!
well, i just did a rear disk conversion on my 2k EX, the rear disk came from a 2k SI. When the car is turned off, the brake pedal seems fine (feels just like stock) but when the car is on the pedal becomes soft, and the lbrake light stays on even though the E-brake is off. I took it out for a test drive and the braking seemed fine (brake pedal just lower like mentioned) and the light turns off for a sec when i brake hard and then it turns on again. I checked the fluid level and its fine. PLEASE some tell whats wrong and how i can fix it. Could it be that maybe i didnt bleed the brakes properly???
PLEASE HELP!! |
Re: Brake light in dash stays on??? HE:P!!! (vsm2k)
You might need to re-adjust the parking brake.
Re: Brake light in dash stays on??? HE:P!!! (Draggin99Si)
i did a search and i realized that i didnt bleed the system properly https://honda-tech.com/forums/images/smilies/emsad.gif I also searched on how to do it properly, but i couldnt find anything. Can someone post instructions??
Draggin99si: I'll try that, hopefully that turns off the light. thanx |
Bleeding the brakes is really easy. I don't even follow the Helm's method because there is a much easier way of doing it, and best yet, it's only a 1 person job. Order these SpeedBleeders. On each pump, it lets old fluid out but the built-in valve won't let any air in. To simplify things further, get the $5 bleeder bag. It is an air tight bag with a 10ft tube that you hook only the bleeder screw. Very cheap and very effective.
http://speedbleeder.com/images/sbani.gif http://speedbleeder.com Every car should come stock with these things. https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draggin99Si »</TD></TR><TR><TD CLASS="quote">Bleeding the brakes is really easy. I don't even follow the Helm's method because there is a much easier way of doing it, and best yet, it's only a 1 person job. Order these SpeedBleeders. On each pump, it lets old fluid out but the built-in valve won't let any air in. To simplify things further, get the $5 bleeder bag. It is an air tight bag with a 10ft tube that you hook only the bleeder screw. Very cheap and very effective.
http://speedbleeder.com/images/sbani.gif http://speedbleeder.com umm, yeah, thats seriously one of the coolest things ive seen yet! Every car should come stock with these things. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> |
Re: Brake light in dash stays on??? HE:P!!! (Peagreenhatch)
Here's the bleeder bag. For another $6, it's worth every penny. It's also forever re-usable.
http://speedbleeder.com/Bleeder_Bag_Combo1.jpg |
Your light will remain on if the brake fluid level is too low also.
But it sounds like you need to bleed them again. |
Re: Brake light in dash stays on??? HE:P!!! (john94si)
thanx for the help guys. Those things seem to be the way to go, are they available in stores also, or is it an online thing only??
check ur e brake might need adj.. also there is a e brake botton. take the consol off and it should be at the end of e brake handle.. when u pull the brake up, the end of the handle hits the botton.. check if it is stuck and clearence.. keep us posted how it goes
