B20b w/ b16 tranny vs B20b w/ gsr tranny.
DELETE
Modified by ProJectCvic at 9:10 AM 6/16/2007 |
the o2 sensor is holding u back more than u could imagine. i was running 14.1's with a bad o2 sensor. and when i changed out the O2 sensor without any other mods to the car i ran a 13.7
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">the o2 sensor is holding u back more than u could imagine. i was running 14.1's with a bad o2 sensor. and when i changed out the O2 sensor without any other mods to the car i ran a 13.7</TD></TR></TABLE>
thanks for the input...that's what i thought http://images.honda-tech.com/set1//smile/emcrook.gif. I m trying to change the sensor asap |
Re: (JDMlyfestyle)
under WOT the ecu is in open loop hense ignoring the o2 sensor(s). p75.. is that a LS ecu? what is it from? |
Re: (crx_88_si)
p75 is an ls ecu
Re: (ProJectCvic)
thats probably why, too lean on the top end. fuel for a 1.8l is not enough to feed a 2.0. either get it chipped w/ b20 maps or find a obd1 crv ecu which I dont think they ever made.
find out what management your friend is running, better yet, swap ecu's and race again https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">thats probably why, too lean on the top end. fuel for a 1.8l is not enough to feed a 2.0. either get it chipped w/ b20 maps or find a obd1 crv ecu which I dont think they ever made.
find out what management your friend is running, better yet, swap ecu's and race again https://honda-tech.com/forums/images/smilies/emwink.gif</TD></TR></TABLE> I m thinking that he is runinng obd2 b/c i saw one plug style distributor if i remember correctly. Swapping ecu is not an option without excess work https://honda-tech.com/forums/images...s/emsmilep.gif. I m running way too lean top end, my car will not accelerate as it does from start to 4.5k. I want to think that the o2 sensor it cause it. I m going to try to fix the o2 sensor problem and have at it again. If that does work, im going to chip the bitch. Do you guys agree that b20/b16 tranny with beat a b20/ gsr tranny though? Short gear will cause the car to accelerater fast. I swap the ls 5th gear to drive on highway only https://honda-tech.com/forums/images/smilies/emwink.gif Modified by ProJectCvic at 3:06 PM 7/28/2004 |
Re: (ProJectCvic)
man..im at work and i can't do anything productive rather than go on h-t... i am still in dissappointment https://honda-tech.com/forums/images/smilies/emsad.gif .
BTW there is no obd1 ecu for the b20. Even the obd2 manual ecu is hard to come by https://honda-tech.com/forums/images...s/emsmilep.gif |
try the o2 since they are easier then a chipped ecu. otherwise you might have to chip your ecu w/ b20 maps, which isnt too difficult to do.
uberdata is your friend. |
Re: (crx_88_si)
uberdata is your friend.</TD></TR></TABLE> deffinatly tuning makes a world or difference. I just think hondata or uberdata is a little excessive for my setup now https://honda-tech.com/forums/images...es/emsmile.gif bump of more thoughts |
uberdata is free https://honda-tech.com/forums/images...es/emsmile.gif
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">uberdata is free https://honda-tech.com/forums/images...es/emsmile.gif</TD></TR></TABLE>
Serious??? Give me the 411 man |
Re: (ProJectCvic)
Dam...i forgot to mention, if i m running 87 octane gas...i m getting a lot of pinging from the motor. I recently switch to 91 and it lessen damatically. I m thinking i m runing too lean
Re: (ProJectCvic)
bump
Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">Serious??? Give me the 411 man </TD></TR></TABLE>
The software is free. You have to socket your ECU. It is a good choice, you need someone to tune (or you tune it) it. http://www.ecimulti.org/uberdata/ |
Re: (turbogixxer)
thanks for the quick reply...i m going to fix the sensor problem and have at it again. Hopefully, it is to my advantage https://honda-tech.com/forums/images...es/emsmile.gif
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">under WOT the ecu is in open loop hense ignoring the o2 sensor(s).
</TD></TR></TABLE> Edit, you use the DX harness, cause that is a heater code. Most of the time it is the wiring, not the sensor. |
Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Edit, you use the DX harness, cause that is a heater code. Most of the time it is the wiring, not the sensor. </TD></TR></TABLE> are you referring to me? i used the dx harness. |
Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">are you referring to me?</TD></TR></TABLE>
Yes, Check the wiring also. |
Re: (turbogixxer)
Yes, Check the wiring also.</TD></TR></TABLE> ya, definately..you always give good advice. Code 41 is a malfunction in the heating system in the o2 sensor. I want to correct that before i buy another 02 sensor. btw..who is that lady in your avatar? That's been in my mind for a while now |
Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">ya, definately..you always give good advice. Code 41 is a malfunction in the heating system in the o2 sensor. I want to correct that before i buy another 02 sensor.</TD></TR></TABLE>
The heater wire is the white wire (harness side), it turns to a shielded wire (to gray wire color and a thicker wire). <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">btw..who is that lady in your avatar? That's been in my mind for a while now</TD></TR></TABLE> My GF https://honda-tech.com/forums/images...s/emsmilep.gif That is Susan Ward. She was in Shallow Hal (she played jill) and The In Crowd (she played brittary). This is the full pic: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D other one: (***I do not know if it is work safe or not, It should be, BUT CLICK AT YOUR OWN RISK***) http://www.we-todd-did-racing....DE%3D |
Re: (turbogixxer)
The heater wire is the white wire (harness side), it turns to a shielded wire (to gray wire color and a thicker wire). My GF https://honda-tech.com/forums/images...s/emsmilep.gif That is Susan Ward. She was in Shallow Hal (she played jill) and The In Crowd (she played brittary). This is the full pic: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D other one: (***I do not know if it is work safe or not, It should be, BUT CLICK AT YOUR OWN RISK***) http://www.we-todd-did-racing....DE%3D </TD></TR></TABLE> Hahahah lol...she looks familar. She is peerrrttee |
