b20 eg
what do i need for a b20 swap in dx eg motor trans b series axels
Re: b20 eg
Did you try searching?
Re: b20 eg
Hope this helps! ;)
92-95 EG with LS B18B Engine or B20. Transmission: Use any Hydro B Series Tranny Mounts: A combination of stock and Integra mounts can be used if a hydraulic B- series transmission is used. Don't forget the T-bracket for the rear mount. ECU: Use the correct ECU or Chipped ECU Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit. Axles: 90-93 Integra axles, 94-up Integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol Upper Radiator Hose: 94-Up Integra LS Lower Radiator Hose: 94 Del Sol Vtec Throttle Cable: 94 Integra LS Or CRV Clutch Hydraulics: Stock Air Conditioning: 94-95 Del Sol Vtec A/C bracket Special instructions: Using OBD II ECU requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on a lot of potential problems |
