b18b1 problems .. help!!!
ok so i finally finish the swap .. 96 LS into 96 Civic HB
and here goes my problems 1. freakin bad motor seeing as its leaking oil by the valve cover and head gasket ? bad head? . bad head gasket? 2. burning oil .. dunno where .. smoke coming from back of motor . oil spat all over the shift linkage and underneath the IM 3. also my temp gauge dont seem right .. its too low when i was driving it earlier .. and my fan dont seem to come on at all .. i know its hotter than that . the temp gauge sits like between normal and cold well any help/suggestion would be great .. thx in adv im gonna go get a new oil pan gasket and valve cover gasket .. |
Re: b18b1 problems .. help!!!
sounds like the previous motor blew motor on it. if he blew the head gasket it would explain that leaking oil....and if the motor was blown bad enough it would allow oil into the combustion chamber which would mean it would burn oil....is it overheating??? what color is the smoke coming out?
96 or not, any swap i ever pick up will have the h/g changed on it, just for peace of mind. figure out where your leaking oil from the motor and get that fixed
then change your headgasket if its still smoking make sure you dont have coolant in your oil and the under cooling thing check your thermostat if the rad fan isnt working, hook it up to direct power and see if it turns on, you may not have the ground hooked up right. |
Originally Posted by maverick31210
(Post 38720194)
Originally Posted by EJ1_Sleeper
(Post 38721056)
ok so i jacked up the car .. and omg .. there was oil like all over the exhaust piping all the way back to the axle back .. some oil underneath the car pass side and all .. thats alot of oil on the car .. wth .. did i forget to bolt something up? ..
Originally Posted by runwitme
(Post 38724194)
Seeing as how the head gasket and the valve cover gaskets are cheap; and the swap is new, I would do both. Just for piece of mind. It will take you about 2 hours to do the whole thing. As far as the issue with the temp gauge goes, do what EJ1Sleeper said. If the fan works then get a new stat. As far as the oil on the back of the motor goes, check the oil sending unit. It's on the back of the driver side of the motor. It has a wire coming out of it and a boot covering it. If it's not that, then there are some oil lines on the back of the passenger side of the motor as well. Jack it up again, start it up, then look under the car to see where the oil really is coming from. We can help you more then. GL!
Originally Posted by JosephColy
(Post 38724209)
sounds like something you would do.
Originally Posted by vtechjunkie
(Post 38724511)
http://img141.imageshack.us/img141/2700/oilleak.jpg
the circle red has a little gap .. the blue is where all the oil are at . it follows the exhaust piping all the way back to the axle back .. would that lilttle gap cause all the oil to spray underneath the car like in the pic? .. |
