b18a1 swap in my eg..now cant rev passed 3k while driving
Recently swapped a b18a1 into my eg and getting weird problems.In neutral,I can rev it to any rpm.While in gear and driving,it sputters around 3k and got no power.Feels kind of like a missfire.Would bad plugs cause a missfire only during driving and not in neutral?
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (darkintegra)
check your fuel pressure. it might be getting the hiccups.
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (biggjerryc)
but if it was a fuel pressure problem wouldnt it get the hiccups even while I rev it in neutral
There's no engine load in neutral so it's not the same as revving up while driving.
Misfires could be many things. My engine never missed unless the engine had a load on it. My problem ended up being my spark plug wires. |
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (sageuvagony)
what ecu?
tune up? cap, rotor, plus, wires, fuel filter, etc. |
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (slambedcivic)
p28 ecu
tune up sounds like a great idea... plugs go bad get clogged dirty whatever i would check those first, check yoiur filters ( air and fuel) and then the other stuff wires, rotor, that kinda stuff
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (btk2334)
I'm surprised nobody brought up the obvious: Your car is in limp mode. If you aren't throwing codes, you have a bad ECU. The exact same thing happened to be after my B18 swap. I suggest picking up a cheap PR4 ECU and trying it.
its most likely your dizzy, plugs, wires. I would just switch it out for known good ones.
bumpp
Re: (Hanmin)
since people here dont read worth a shit. im gonna point out the obvious....
youre running a vtec ecu on a non vtec engine.... swap it out. or get it socketed and disable vtec and the other things that need to be done. I can do this for you or you can swap me ecus and ill send you a true LS ecu. edit... sorry. johnnywash can read. |
Re: b18a1 swap in my eg..now cant rev passed 3k while driving (johnnydelcampo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnydelcampo »</TD></TR><TR><TD CLASS="quote">bumpp</TD></TR></TABLE>
Why are you bumping? |
Re: (slambedcivic)
the vtec ecu running a non-vtec motor would have nothing to do with it...plus i changed my wires and it solved the problem.thanks guys
Re: (darkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkintegra »</TD></TR><TR><TD CLASS="quote">the vtec ecu running a non-vtec motor would have nothing to do with it...plus i changed my wires and it solved the problem.thanks guys</TD></TR></TABLE>
lol. if you say so. https://honda-tech.com/forums/images/smilies/emthup.gif |
