Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   Air/Fuel Gauge giving a CEL (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/air-fuel-gauge-giving-cel-1392917/)
brockscivic Oct 4, 2005 07:46 PM
Ok, ever since i installed my Autometer AF gauge Ive had this weird CEL. IT started about 3 weeks after installing it. It would come on after driving the car 25-20 mins and would say code 1. If you turned the car off and back on it would not show the CEL until you drove it for a few minutes. Would having the AF gauge tied into the harness at the ECU give a CEL? Or is my oxygen sensor on its way out?
Hatch It Oct 4, 2005 07:57 PM
Re: Air/Fuel Gauge giving a CEL (brockscivic)
Hmmm the gauge shouldnt give you a CEL, maybe the way you wired it? Uninstall the gauge and see if it happens. If it goes away there is something wrong with your instilation if not it could be just a coincidence.
good luck https://honda-tech.com/forums/images/smilies/emthup.gif
LShatchie Oct 4, 2005 08:01 PM
Re: Air/Fuel Gauge giving a CEL (Hatch It)
yeah when I installed my autometer a/f gauge I was getting a CEL and it ended up I had the wiring wrong
brockscivic Oct 4, 2005 08:04 PM
Re: Air/Fuel Gauge giving a CEL (LShatchie)
i know its wired into the right wire (the white signal wire...i cant remember the slot) but as far as connections...i think i screwed up using the crimp connectors instead of soldering it.
Hatch It Oct 4, 2005 08:26 PM
wait you just have a 92 LX?
You hsould only have a wire for power, a ground and the last one thats the signal, which you can run through the firewall and splice right into the 02 sensor on the header....
well good luck
LShatchie Oct 5, 2005 04:06 AM
does the gauge work properly?
SRCivic97 Oct 5, 2005 10:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">does the gauge work properly? </TD></TR></TABLE>
It's a dancing light show unless you go wide band so that question should read..
"Do the lights dance?" https://honda-tech.com/forums/images...s/emsmilep.gif
tr0n9h Oct 5, 2005 10:47 AM
can wrong wirring affect the car performance, cuz mine wire wrong at the moment and its show the cel also
