AC Compressor getting no power
Old Aug 15, 2007 | 06:13 PM
imjustagirl's Avatar
Default AC Compressor getting no power
I have a 93 honda Civic DX. I am not getting any power to the ac compressor or low presser cut off. However if I put a jumper straight from the battery straight to the compressor it starts up fine. I also dont have a scematic (I just got this car) to see how the whole thing works, or to see which fuse slot goes to the ac / compressor. Any help with these things or what you think is the problem. Thanks!
Old Aug 15, 2007 | 06:19 PM
Nbboy7's Avatar
Default Re: AC Compressor getting no power (imjustagirl)
check the clutch and most likely the compressor is bad
Old Aug 15, 2007 | 06:20 PM
crazyguy's Avatar
check the ac relay and ac harness.
Old Aug 15, 2007 | 06:23 PM
schardbody's Avatar
Default Re: AC Compressor getting no power (Nbboy7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nbboy7 &raquo;</TD></TR><TR><TD CLASS="quote">check the clutch and most likely the compressor is bad</TD></TR></TABLE>
that makes no sense, if she hotwired the compressor and the clutch engaged both the compressor and the clutch are fine.
so here is where i start, jump the pressure switch with a paperclip or whatever, if your clutch engages then you just need refrigerant. if it doesnt start working backwards in the system. chances are being that its a honda and the system is usually pretty reliable aside from leaks its most likely just low on refrigerant.
Old Aug 19, 2007 | 08:54 PM
Thank you very much. I will have the refrig. done and let you all know if that works.
TXMAG
Jul 11, 2014 03:48 PM
d-ramey
Acura TSX
May 23, 2014 05:47 PM
SIR 1.6
Aug 1, 2012 05:23 AM
PL_RACER
Honda Civic (2006 - 2015)
Jul 24, 2012 07:20 PM
wizzards581
Jul 1, 2004 11:00 PM
