Re: 99 si/b18c1 swap won't communicate with scanner for emissions test
Originally Posted by gwarfare
(Post 46404081)
In a perfect world yea it would work,but u will have to see what was cut,was the knock Senor cut,etc...You will have to do a trail in error and see what happens when u plug the new ecu in, I can bet it won't work,been there with this same issue.
Other than getting the proper ECU the only other things that need to be done are:
perform CKF trick --> http://ff-squad.com/wp/?p=309 Add a secondary O2 sensor - this may already be done in your case. The car is at least wired for it, so it's simply a matter of installing an O2 sensor and plugging it in (you may need to weld a bung to the exhaust depending on what's on there now though) That should really be it, EX/Si models already have a fuel tank pressure sensor so you should have no issues there. As well both OBD1 and OBD2 B-series vtec ECUs look for knock so it should already be wired (unless you have a chipped ECU and it was disabled and never wired in) |
